Since the latest update (6.A.025.0) my Fairphone 3+ and my partners Fairphone 3 have started to completely drain the battery in 2-3 hours. The system has become seriously unresponsive, and phone is getting hot on the core-module/motherboard.
This is a sudden change in the behaviour of the phone (began yesterday morning 6 March 2024).
I was considering posting something today since my phone has been getting hot if I leave apps running and it is less responsive than usual with the equivalent apps open. However, I installed the recent update several days ago, seemingly without any immediate effect, and I am not experiencing rebooting issues⦠(I have actively rebooted a couple of times today, but it didnāt appear to help at all.)
I kind of have the same issue since recently: my phone discharge quickly (3-4h after full charge I am below 20%) and heat up while I am not doing anything with it.
I tried to put it in battery saving mode today but it does not seem to change anything.
I just charged mine to near full so lost the opportunity to check the historical usage (as far as I can tell?), but will keep an eye on it. Having said that, it does seem to have settled for the time beingā¦
I am having same issue
I bought a new battery thinking that was the issue - it isnāt, the brand new battery is more or less the same
I tried ākickingā the battery but that hasnāt helped
I am on 6.A.025.0
There are NO app usage above 2%
I am about to commit hours resetting the thing
Not impressed
Thereās now a similar report In the German-language Fairphone Facebook group (not public), but from someone who is still on Android 11 (so no update to 6.A.025.0). Perhaps recent Google updates from the Play Store are the culprit. That user report cites Facebook and Chrome as the biggest consumers.
Have you also installed any new applications? I upgraded my FP3 (Default OS) to build 6.A.025.0 a week ago (or so) and havenāt noticed anything different in terms of battery life (still good even though it is more than 4 years old).
I have some system apps disabled (I had those before the update as well). Maybe itās not that, but to look for a possible cause: maybe itās one of those apps that are causing the problem? In my case, I have the following apps disabled:
Hmmmm⦠I uninstalled the latest app Iāve installed (MyFitnessPal), yet Iād be surprised this is the issue.
I deactivated āGoogle TVā that I never use and showed 5% use, Iāll keep you posted, thanks for the tip.
Note : I just charged my phone to 100%, will monitor the apps draining the battery and re-post.
Okay, so I tried uninstalling updates and disabling Apps.
I uninstalled updates for
Google
Google Photos
XBox Game Pass
And the phone is feeling more responsive. Iāll see if it is actually improving the battery life, and if it does I can try to work out which App was responsible.
I experience a similar problem. My Fairphone gets really hot (I could narrow it down to the use of Spotify and navigation apps like Osmand).
Sometimes I charge it in the car while navigating and the battery drains faster than the charging process ( so it looses battery power while charging).
Probably google is force-updating all the apps? I had a strange behavior with my fairphone 5 on saturday (or yesterday). Took it out the bag and it was really hot (and showing a warning i should keep it well vented in case i would be updating apps) although it was not doing anything unusual.
I just checked and both my fairphone 3 and fairphone 5 have all apps updated to the latest version. Usually the apps do lag behind for some reason.
