Hi all!
My first post here, thanks in advance for any help ![]()
After forgetting my fairphone 3 in the train a couple months ago I bought another second hand fairphone 3 (as I was very satisfied with this phone). As this phone is second hand I don’t know the history of the phone. At first I ran it with the stock fairphoneOS without any issues for a couple of hours. Then I switched to e/os, now it is running e/os v1.14
For some weeks now I have had troubles with the mobile data, sometimes I have a 4g connection, but it stops very often. Sometimes the connection comes back when I go to the internet settings… My girlfriend also has a fairphone 3 running the stock OS with the same provider and has no problems with the data, so it has nothing to do with coverage.
Does anyone has some ideas to find out where the problem might be? (Hardware, OS, APN settings, etc…)
I would like to check out some things before reinstalling with stock OS to see if it helps…
Another issue started this week: the phone is not charging anymore above 40 percent, and the last days not at all. I keep it working by swapping out batteries with my girlfriends phone, which is charging fine (so also both batteries are fine) when I plug the charger the led comes on, but the battery symbol does not show the little charging symbol. Again, is there a way to check whether this is a hardware or software issue?
Thanks! And have a nice day ![]()
Jeroen
