Dear reader,
A few days ago, I bought a Fairphone 3. It is still running Android 9, security patch level; 5 October 2019. If I check for updates, I get the message that the system is up to date. Is this correct, have the latest updates been installed?
Thanks for your help
This is definitely not the latest update . What carrier are you on? Some hold updates back, but October 2019 seems extreme.
Firstly you are not a Vodafone customer or Vodafone MVNO as this has led to issues as here?https://forum.fairphone.com/t/system-update-does-not-work-on-fairphone-3/64039
My carrier is T-Mobile. Thank you for your assistance.
Do you use a firewall App or similar which could block the necessary traffic?
Is the phone connected to a WiFi network once in a while?
It is currently connected to WiFi. I bought it at a second-hand store, but it proved brand-new. Can that have anything to do with it?
If you don’t find any other solution, you might want to try to manually install the latest OS version using a computer:
Thank you, urs_lesse. I manually installed Fairphone OS Android 10 and the issue has been resolved.
system
Closed
December 24, 2020, 7:21pm
9
