Fairphone 2 unusable while charging
Hello all
I have the same issue, though i think “unusable” would be a strong word in my case.
At times, while charging, the touchscreen stops responding. Then the only way of waking it up is to unplug the charger, and toggle the screen off then back on.
But it only happens at times.
Okay, that’s really interesting. AFAIK, there’s 3 ways USB chargers handle the data pins:
  1. Leave them unconnected to anything (common on the cheapest chargers);
  2. Short them to ground. According to spec, this should indicate a dedicated charger;
  3. Use resistor voltage dividers to show data lines at a specific voltage, that according to spec indicates a certain allowable charge current.
A 4th option is to have some IC send a signal over the data lines, I think recent Apple chargers do that. If the touch screen problems only occur on one or some of these types of chargers, that might indicate what the problem is? Unfortunately, I don’t have the equipment to see what my charger’s data lines are doing.
I do have a USB “charger” cord (no data lines), and using that with the wall charger seemed to make the problem worse. However, the phone still didn’t have this problem when I used that cord with a laptop USB port.
I’ve since received my replacement fairphone, and although it has the same issue it’s much less severe (to the point where I can live with it :slight_smile:). I guess this makes it seem more like a software problem, but there is some variability between individual phones. I’m very curious to see what will happen after the next software update.
To be fair, considering my landlord’s approach to home renovation I wouldn’t be shocked (or perhaps I would be :stuck_out_tongue:) to discover that the wall socket’s ground isn’t connected.
Same for me - when using a usb cable…It’s annoying! Any word from the fairphone people?
Having read half of this thread, but not all, I hope to be asking something new, that hasn’t been answered yet.
My charging goes fine & fast… but: when my Fairphone2 is connected to a charger I often experience problems when using my phone at the same time:
  1. when I scroll through a list of people (address book) the screen jumps up and down, very quickly
  2. when I touch 1 app I often see that Fairphone2 opens another app which is nearby, but not the one I picked.
Conclusion: when linked to a charger/energy grid, the touchscreen of my Fairphone2 becomes ultra sensitive and weird.
Any ideas on how to fix this? Or, another question: can you guys work on your phone and charge it at the same time without a problem?
Thanks!
I don’t have any problems with charging and using the phone.
I do have about 5 different chargers and always I can use the phone.
Hmm strange. Where are you located? How new are your “power cables” (the one in the house)? Maybe it has something to do with how the power gets to the phone…
Nothing new regarding to 1.2.8 (or next) update, Fairphone team ?
Are you aware that this forum is intended for Fairphone users to discuss with each other? Not for official Fairphone Team responses.
Hi Lidwien, how are you?
It is not because i asked “Fairphone team” that i am waiting an official answer :wink:
But thank you for your contribution, by the way :wink:
Did you note a difference about this bug with news FPOS release ?
I my case, since 1.2.8, i note more frequent/systematic screen freezing with one of my charger (HTC 5v/1A)…
After applying the update my screen is still freezing during charging.
But the charging itself is so much better after the update.
Same problem here: while recharging the phone gets “wild”! I can’t use it well since it doesn’t work well when I tap icons or words or unlock patterns (the worst frustrating thing, guys!). Adding this trouble to the microphone not working well at all (people can’t simply hear me!) I must say that buying FP2 was NOT a good idea :cry:
With how many chargers have you tried that? Try also charging the FP2 on your PC. Do you have this problem with all your chargers?
Same problem with different charges and connecting the FP to the PC.
Anyway suggest me some chargers that seem going well and I will try them.
Thanks.
Same problem here.
On some chargers the touchscreen gets totally unresponsive during charging.
I’m not sure if this is a problem with the charger or with the phone. It might be a hardware-problem or a software-problem with the fairphone 2, that is triggered by some chargers.
OK. I have an Anker charger, without causing touch screen problems.
The charger from a Microsoft smartphone does the trick for me. The charger of my old FP1 didn’t…
Ok, guys, Anker recharger seems working fine! I don’t know why thou… So it would be good if FP developers added to this tip to the specs
Issue still exist in 1.3.6 !
