Fairphone 2 Ubuntu Touch
We achieved a new milestone! Ubuntu Touch for Fairphone 2 is calling! Check it out: http://bit.ly/2iPQpND Help us with a fully working device: http://bit.ly/2ePv1Wh
That sounds great. Seriously thinking about pre-ordering the fairphone.
Uncovered links:
Nice job, the Ubuntu Touch OS is now able to make calls with FP2 phone :slight_smile:
Perhaps I’m too impatient, but does the new image is already available? On the seafile depo the last system.img is 2016-12-22 so anterior to M. Gripsgard great announcement !
@oli.sax, the last seafile system.img is 19h old now
Hello everyone,
I really like the layout and look of the Ubuntu Touch. But I was wondering how the data security of Ubuntu touch is compared to e.g. Android, Cyanogenmod etc. Would be really happy if someone could enlighten me :slight_smile:
Hello everyone,
first of all thank you very much for the great work you have done.
I’m planning to flash ubuntu on my FP2 this weekend but I wanted to ask: is the data working in 4G?
Moreover I saw on ubports that the GPS is not working and I was wondering if there are plans to make it available in the future.
Thanks
Hy together,
sounds great to have ubuntu touch on the fairphone, but my installation failed.
I got ubuntu running, what I see running top. but exept ā€œFairphone powerde by andoidā€ nothing else running on the screen.
What has been my mistake?
added my share to the bounty. Let’s see. I am basically booked out all the time to do some real implementations. Thus I share my hard earned dough :smiley:
Greetings.
Hi bastos!
It’s difficult for me to spot the mistake, but i did succeed once the installation when following all the points at the beginning of this guide. Perhaps you can start again step by step with paying attention of not misspelling any command-line? Did you had the new recovery screen at step 6 ?
I intend to test again with the new version when I have some ā€œgeekā€ free time, when it’s the case I’ll let you know if this procedure is still working :slight_smile:
Thank you #oli.sax for your reply. Until now I did not follow the steps in this thread.
What I have done is following https://devices.ubports.com/#/FP2 but it has not been successfull at all, so I tried different ā€œgoogle search optionsā€ and succeeded to have a ubuntu to login and to run top.
I will try asap the steps in this thread, when ā€œI have some ā€œgeekā€ free timeā€ too :slight_smile:.
Indeed the procedure on the main ubport website is generic and is not working for FP2 due to some limitations…
The working FP2 procedure is the one described on this topic, and is also available as a PDF illustrated tutorial written by Audio Dandy, Jan, Ivan (Noviski), Tiago Carrondo & Fuchur777. Thanks to them ! :slight_smile:
I got my phone working :slight_smile:
With the Magic-Device-Tool: https://github.com/MariusQuabeck/magic-device-tool
The channel has to be ā€œdevel_rc-proposedā€ otherwise there is no screen.
Much thanks to the guys on the Telegram group ā€œFairphone 2 + Ubuntu Touchā€
Nice tool ! Did you tried to call someone within UbuntuTouch ?
Yes. Works smooth calling and getting calls. Once I had an echo problem but only with one peer.
Hi pat !
I don’t know about version 14, but I know that from version 9 to version 10 the GUI was broken, as it is stated in post 1 of this topic :
What I advise you is to try one of the two working methods:
Best regards,
Olivier
Hi oli, thank you.
I just saw the PDF tutorial and deleted my post after this.
I think there are some problems regarding the fact that version 14 is not available:
  1. my SIM card wasn’t recognized by UT and i didn’t get asked for my PIN. will this problem be solved after setting the provider data manually?
  2. CalDAV and CardDAV does not work with UT 9 or UT 10, is it right? I just saw the shell script for sync with ownCloud, but i need both for SOGo. Does someone know a solution for this issue?
  3. I recognized that that 4G isn’t available, but probably it depends on the fact that SIM isn’t recognized
If it is possible to solve these three issues, i would definitely use UT on my phone and support the developement as effectively as possible
Hi pat!
The versions you are mentioning, for my understanding, are from the stable channel. If you want fully working device you should install via the rc-proposed or devel_rc-proposed channel, one way to do so is using the Magic device tool already mentioned some posts above.
I’m using version 251 from the rc-proposed channel and right now I can assure you that both the sim cards are automatically recognized and 4G is working. For what concern CalDAV and CardDAV I don’t know. In case you could consider to join the telegram chat Fairphone 2 + Ubuntu touch (link above) people are very welcoming and they helped me a lot.
Best
Thank you, aronne. I’ll give it a try now
hi people. i’d like to ask those of you who have deeper insight into the technical aspects regarding the move from click to snap. as far as i have understood, the fp2 will not be capable of running snap packages, right? in the light of reading that the email client dekko will no longer be developed (while still getting bug fixes) for click but only for snap i wonder, if using ubuntu on fp2 has to be considered as something which would be called ā€œriding a dead horseā€ in german. meaning: if i would be using ubuntu on my fp2, is there any chance i can run decent software in two years? will the community try to make snap work or will we be stuck with outdated os and software? background: i’d like to have an os which i can use steadily for several years and not to have to switch every second year. right now i am running sailfish os which works quite well, but as we all know, jolla’s future is constantly uncertain. this doesn’t mean i have deeper insights, at the moment they seem to do very well. ubuntu seems nice, too, but as written above, i would want to run an os with abright future.
so, can anyone of you enlighten me and explain what the move means for ubuntu’s future on fp2?
cheers!
