Fairbuds - no audio playing
My fairbuds have stopped playing audio. They connect and play the “connected” message, but no sound from music player or other apps. Other headphones are working.
I have tried repairing and factory resetting the Fairbuds but it makes no difference. The Fairbuds app connects to them okay.
Any ideas before I send them back? They are only 7 months old as is the FP6 that I’m using them with.
Iain
Is the FP6 the only “source” you are using the Fairbuds with? No “competition” from other sources of sound?
No, they are only paired with the FP6, nothing else.
The connected message tells us that at least the speakers are still okay. Does calling still work? From what I know, BT headphones use different BT profiles for playing music and for calling. Can you try to pair them with a different device (mobile, notebook etc.) to see if the problem is there, too?
So, I tried pairing them with a laptop and an iPhone and there was no audio in either case. Noise cancelling is working though.
But then I reset them and re-paired with my FP6. Still no audio with apps, but with an incoming call I did get audio. Curious!
Seems you may be right about the BT profile, but how to fix that?
Thanks
Iain
The answer seems to be to take the charging case battery out for a short time. After that, all good again. :man_shrugging:
Seems maybe the 10 second button press reset doesn’t reset everything?
Thanks anyway for the support.
That’s really unexpected, but I’m glad that it helped and that you reported that back here, so others can find it in case they have the same issue. Happy listening!
Mmmm… Issue has occurred again and this time removing the charging case battery has no effect.
Issue:
  • FP6
  • Buds beep and play the connected message when inserting in ears.
  • Fairbuds app connects to them okay.
  • Sound from apps like Musicolet and Duolingo is not playing through buds.
  • Microphone seems to work in Duolingo though.
  • Audio from incoming call is playing in the Fairbuds though.
  • They are only paired with the FP3
I’ve tried:
  • Forgetting and repairing
  • Factory resetting Fairbuds, forgetting and repairing
  • Rebooting Fairphone
  • Removing the charging case battery
  • Tried pairing with another device. Still no audio in the Fairbuds.
Any more ideas?
Thanks
Iain.
Fixed again:
Opened Fairbuds app
Connected buds
Pressed the ‘bass boost’ button (or whatever it’s called)
Buds started playing audio
Switched back to ‘Flat’ still playing
:man_shrugging:
Enabling Bass Boost did the trick for me as well. This issue occured for me after installing the Fairbuds app.
Thanks for sharing this solution.
It seems to happen every few weeks to me. A minor annoyance as long as the Fairbuds app connects to the buds, which it often seems not to want to do. A new app version installed last week so hopefully this improves things.
Iain.
