Fairbuds left ear Crack loudly when ANC is enabled
my XL headset has developed a hiss/crackle only in the left ear and only when ANC is enabled, not the ambient mode or ANC off.
it builds and sounds quite obvious like a Crack, a waterfall or tv static.
Any one experienced the same pb and found a solution. I read a previous topic ( Fairbuds XL noise cancelling hiss) about it but no solution were found. Perhaps by buying a new left ear ?
I already checked the microphone hole by removing the cover, but that didn’t help. I also updated to the latest firmware, but no luck. Any other hints ?
I also experience the same issue and have not yet found any solution. Have you maybe contacted support for this? I also recently updated the firmware to the newest version (shown in the App), but it did not help.
Unlike you, I have the problem in ANC as well as in Ambient mode, unfortunately.
Thank you for your answer ! Yes I done the firmware update and contacted the support and I’m waiting an answer.
I will let you know if I find any solution.
Vincent
@VincentD1: Any news on this topic from your side / Fairphone support?
Yes, the support was ready to repair the material, unfortunately, I have no proof of purchase. So I have to solve the problem my self. I’ll probably try to do a self repair and if whith no succes probably by a new left speaker.
Regards,
Vincent
I have the same problem right after unboxing my new Fairbuds XL. I noticed the sound disappears when the Fairbuds XL are charging, has anyone else noticed that too? And has anyone had the same problems after they got their Fairbuds XL back after repair?
Unfortunately, the support didn’t repair it because it is a second hand earbuds with no proof of paiement
Mine developed a similar issue over the past week to the point that using NC mode is practically impossible due to the annoying background noise. I have now submitted a support request and will report how that turns out.
(I had the chance to exchange parts with a known-good model and could confirm that the issue is with the left speaker. Namely, switching speakers between the two devices moves the problem to the other device without changing any other parts.)
Update: I just got my headphones back and they were actually fixed!
The whole procedure took a good 3 weeks from first contact to support until now and I had my doubts in between if they could reproduce the problem. In the end they changed the left speaker just as I had already diagnosed before.
To sum it up: All went well except for the pretty long delays when exchanging messages with support. So if your headphones are under warranty, they certainly should be able to help you. Otherwise your only option will be to buy a new left speaker on your own.
