Extremely slow Spotify loading
Hi folks - I’ve been using my fair phone 5 android phone for a few months now and Spotify is especially has been extremely slow and unstable. Often I have to open/close/force stop/clear cache several times just for it to open and run. When it does load it will take a second or two to load simple menu transitions and song playpack takes 5-10 seconds to start even from local files. I’ve checked and there are no battery optimisations, and other apps load perfectly fine it’s just Spotify giving me this issue. Also app is up to date, as is the android system. Anyone had this/know of a fix?
I had this problem on the PC version once, I found various suggestions online. For me clearing the cached data worked, or you could try reinstalling.
Some things that come to mind that you can try are:
  • check if battery-saver is enabled
  • restart the phone
  • reinstall Spotify (as already suggested)
  • as a last resort, make a backup & factory reset the phone (if you don’t mind the hassle)
