Export of Contacts -> doesn´t work correctly - FP5 - CalyxOS V. FP5. 5.13.0 - Nov. 24 - UT2B.B.072.20240920
Hey,
I can´t Export my contacts from my FP 5 with Calyxos. If I create the “.vcf” there seems to be only on contact inside. It got only about 53 kb and if I open it with Outlook only one contact is shown.
Do you have any Idea what the Problem is?
I did install the new Beta Version of the Calyxos a week or two ago.
Now it runs:
Changelog
CalyxOS 5.13.0
November 2024 Security update
Chromium: 130.0.6723.102
Chromium: Improve migration of adblock filters from Bromite
Update all included apps
Update kernel
FP5
Update to FP5.UT2B.B.072.20240920
I changed form Beta to “Stable”.
I do not want to have any Bucks as I am no pro…
Did you try an alternative app yet? Fossify Contacts is an open source contacts app that can export contacts. If you’re looking for a workaround or want to report a bug, I think the CalyxOS-community is right place for that.
Did you try to open the file with a text editor yet? 53kB should be sufficient for a lot of entries (not only one).
The format of the file should be rather easy to read (I hope even when not being a pro).
You might find tips e.g. here:
Might be an issue with different versions of VCard file formats:
BEGIN:VCARD
VERSION:2.1
I once succeeded in importing a .vcf-file only after changing the version number with find and replace :wink:
