Experiences with TUI-ConsoleLauncher on FP6?
I was thinking of changing Launcher on my FP6 (e/OS Murena) and going for the TUI-ConsoleLauncher from fandreuz.
Has anyone tried it with FP6?
Are there any known issues with installing and using this as a launcher on the FP6, or should it generally work without major problems?
Thanks!
The last update was 6 years ago it seems. It is very likely that you will run into issues but even if it works, it might break with future Android-Update.
I’m currently creating my own purely text based launcher, will publish in a week or so into the store in case you are interested (Im using FP6 with Android).
Far away from the features that tui supports and likely I will never implement those, my main focus is to open apps purely via text commands :slight_smile:
The first release is now available in case you are interested :slight_smile:
This is super nice! Thanks for sharing I will try it out for sure. Is theere a repo and/or source code opened for it @David_Peer ?
And just for info, the TUI-ConsoleLauncher does work with the FP6 and murena installed for the only exception of a couples of features (the weather visualization for example, nothing crazy).
Currently not but Im really considering to open source the repo would have so many advantages, I will let you know if I do it :slight_smile:
