Excessive outgoing noise reduction during calls
During calls, the other person often cannot hear me if I make non-word sounds like laughter and humming.
  • I have /e/OS installed by hand, to the latest version (3.4-a15)
  • The problem does not persist if I use a recording app
  • My carrier only allows 4G and 5G calls
Issue was from day one. I had similar issues on my FP3+ when I switched to 4G/5G.
I’ve tried adjusting SIM settings but nothing seems to help. Phone app does not appear to have a way to adjust its noise reduction.
Will also post this question on the /e/OS forum. If they find a solution I’ll link it here.
What happens if you set your SIM-card to one 4G/3G/2G?
Other users have seen better performances when excluding 5G.
I tried setting the “Preferred network type” to 4G. No difference.
(In *#*#4636#*#* it says “GSM/WCDMA/LTE (PRL)”.)
