Encryption unsuccesful error
My FP2, Android 10, has developed an Encryption unsuccessful error and has become unusable. It tells me I need to do a factory reset. Removed the unused SD card. Tried safe mode. Didn’t help.
I would like to avoid a factory reset.
I’m aware of 3rd party software ( iMyFone Fixppo for Android) that claims it can solve the problem. Does anybody have experience with this?
Any other suggestions or solutions? Thanks!
I have had the same issue some time ago with Lineage OS and indeed the only thing that I could do at that time was to do a factory reset and set everything up from scratch again - I didn’t have the time for experiments unfortunately.
Here is the short discussion that I started at that time:
I have no experience with this software (and never heard of it before). I took a quick glimpse at the website, but there is no description beside some simple steps:
  1. Select Device Information
  2. Download Firmware
  3. Connect Device to PC & Repair It
So I assume the software does nothing but reflashing the firmware, maybe there are some problem related tweaks implemented. If no one else used it successfully before, I would contact their support and reassure that your data isn’t lost. But to be honest, it sounds to good to be true… Haven’t found any other solution and I can’t think of a way for the software to backup the data from an inaccessible partition.
I had the same feeling about Fixppo.
@Martin_Anderseck : looked at your thread and saw TWRP mentioned. Looked into this (twrp.me), but I don’t have a clue what to do with it.
Was this SD card installed as expansion of internal memory or as external / portable? If the former, could have been a contributory factor in the encryption bug, even if unused.
I agree.
I’m not sure. It never worked well and I have tried to use it for a long time. Now, I have removed it.
I’ve already done a factory reset (I’m in a hurry to be able to use the phone again). Still interested in more elegant solutions for the future.
