How can I edit the hosts file? I’m aware of this post, but my understanding is that it may not be necessary to root the device when OSOS is used, or alternatively that rooting is easier. I tried to remount the file system (after su) in order to edit hosts, but got “Permission denied”. Thanks.
No, you don’t need any special actions. Did you get an error message after su? Or was the prompt a #-sign? how did you do the remount? it is sufficient to type
mount -o remount,rw /system
no need to specify a fs type, if this is correct at all…
Thanks for the response, Klaus. I tried a couple of things (all via adb shell
su; cat /sdcard/Download/hosts >> /etc/hosts
. This gives me/system/bin/sh: can't create /etc/hosts: Read-only file system
Okay, I tried remounting read-write:
mount -o rw,remount -t yaffs2 /dev/block/mtdblock3 /system
but that produces:mount: Permission denied
As you suggest
but that also gives mePermission denied
After su
, the prompt is not a #
but still a $
. Does that mean that I’m not root? I tried the same commands on the phone via the Terminal Emulator – no difference.
Ok, I found the solution. I had to activate root more:
- Go to settings -> about phone -> tap build number 10 times.
- Go to settings -> developer options -> root access and select “Apps and ADB”.
- Open terminal
- Enter
su
- Enter
- Edit
/etc/hosts
yes. the error happens on step 1. su is “interactive”. the command after the ; gets executed after su finishes. that is, after you “left” root. just type su all on its own, and the you’ll get the # prompt. after that, got ahead with the rest of the command
