e-OS and hearing aids
Any idea, or hope, of Murena e-OS supporting hearing aids? This will probably be a deal-breaker for me.
Depends on the hearing aids, I would say. Which ones do you have in mind, or which technology has to be present and working on the phone for them?
Also perhaps search or ask in the /e/OS forum
 https://community.e.foundation/search
Possibly. Don’t mess with medical stuff unnecessarily.
Hi, I use Phonak hearing Aids. They are supported via the Phonak App which works fine on e-OS. (previously used on a standard Android system).
I guess it depends on which hearing aids you have and if they have a supporting App.
And if such an App has any built-in Google dependencies (most Apps in existence do) which could fail at any time for any amount of time on /e/OS.
Hi – thanks for the responses.
I have UK NHS Danalogic hearing aids, with the BeMore App. Used to work fine on my Pixel 4, but no such luck in FP6 e/OS
As I understand it, Danalogic uses the Bluetooth Low Energy tech with is the industry standard now, and the ‘LE’ element might be the problem(?) I have no problem connecting to my Bose speaker.
But I do, connecting to our car, a Skoda, so it does rather look like a Google OS would suit me better.
and a german topic
I have an open ticket in the support forum (https://support.fairphone.com). The latest answer is
Murena has informed us that a permanent fix has already been developed and is expected to be included in an upcoming system update (v3.8/v4.0). In the meantime, they suggest trying a temporary workaround that has helped other users resolve similar audio routing issues.
Could you please try the following steps:
  • Go to Settings > Network & internet > Mobile network and select your active SIM.
  • Disable VoLTE (4G Calling / Enhanced LTE).
  • Disable Wi-Fi Calling.
  • Unpair your hearing aids, restart your device, and then pair them again.
The workaround, for me did not help, but I wait for the /s/os update
Hallo an alle
Auch ich habe diesen Workaround ausprobiert, und wie bei den anderen hat es nicht funktioniert.
Da wir momentan bei der Vers. 3.7.1 sind, wĂ€re meine Frage danach, ĂŒber welchen Zeitrahmen wir bis zu der avisierten Lösung in der Vers. 4.0 sprechen.
Ich liebe zwar mein FP6, aber noch mehr wĂŒrde ich es lieben ein Telefonat ohne stĂ€ndiges Nachfragen fĂŒhren zu lönnen.
Mfg, Horst
@Kugel-statt-Google kindly stay in English in this topic, you can use a translation tool and copy it here.
