This speck of dust is somewhere in my camera module - do you have suggestions on how to get rid of it?
Welcome to our Community ![]()
While it’s hard to tell where exactly the “intruder” is located in your module, this topic might provide some ideas for a potential fix:
Thanks for the reply, but I don’t have a crack on the camera glass so I don’t think that topic will help.
Did you only read the title and what got cited here, or did you really have a look?
Yes I did, and the discussion was about changing the camera module. So what you are saying is that the only option is to buy a new camera module?
You can check on iFixit, whether and how it is possible to disassemble the camera module and try to clean its inside.
Ok thanks, I’ll check that out!
