I just started using dual SIM in FP3. When I set calling preference to ‘always ask’ I have to choose every time. How can I remember the choice per contact?
Colleague with FP2 has the option to check a “always use this” box when making a call, but this doesn’t show up in my FP3.
You could try via the contacts app: select the contact you want to edit, then long-press the phone number you want. The menu that pops up usually has options to set a SIM as calling SIM for the selected number (as well as an option to set a number as default number for contacts that have more than one number).
