I’d really like to be able to conveniently put my FP2 in a dock in my car, immediately connecting headphone audio and USB charging.
Now of course this will require some hacking at the fairphone cover side as well, since the USB port and the headphone jack are at opposite sides of the phone - but the encouraging results by @Cherry97 make this sound like a fun challenge ;).
I bet there’s people with more hardware design skills than me around here - how would you design the connection between such a dock and the phone? Any recommendations, ideas, …?
Maybe you can build a dock that incorporates wireless charging via the QI extension. If your car radio supports bluetooth, you could connect the audio this way.
… with a ‘pack panel’ and a way to make it ‘slide open/shut’ horizontally? Yeah that sounds like it’d work! I should work that out further.
Hmm maybe I should keep it to 1 hack at a time
Unfortunately my car (2011 Alfa MiTo) only has bluetooth for speech/headset, not for A2DP. Of course I could get a separate bluetooth connector, but at least the cheap ones have pretty terrible audio quality, not sure if that makes sense.
I’d like to use it in landscape mode actually, so that’s not a problem
You could use a 90° left/right turned micro-USB plug, so the cable will go down instead of sticking out.
I wonder, how you manage to get the plug for the headphone in, as you still have the phone in an angle, when plugging it in.
The construction might need to be made of two parts with some spring-mechanism in the middle to pull them together and fixing the plugs. Or the plugs are put into place after inserting the phone.
I really would like the see what progress this makes.
I’d probably make a dock that only has one part, but I’d lead through both the USB and the aux cable.
The phone would dock into the USB-connector (be careful with the mechanic stress on the bottom module of the FP2) and then you’d plug in the aux cable in the top.
But as I understood it, he want’s to make it landscape oriented, so the plugs are left and right rather than top and bottom. So you can’t plug it in at the bottom.
With regard to the stress on the plugs/connections, I really would aim for a design, where the plug is put into place in a straight way and not at an angle.
