Do not disturb now vibrates on notifications
I used to turn on the Do Not Disturb mode with the switch, specially when I went to the cinema or so and I don’t want to even know if anything comes to my phone. However, since last update (FP6.QREL.16.82.0) it started vibrating again.
Is anyone else facing this? Any fix?
Hi, have you checked the Vibration and haptics settings?
I turn all the vibrations off.
Thanks for the reply!
That setting seems to be for everything, not only on do not disturb mode. Tried flipping, changing mode and it remains as is.
I want to have vibrations on until I put DnD mode. Then switch back to normal as I could before.
Oh, Ok. Sorry I couldn’t help..
Looks I found the solution myself. Within do not disturb settings it had activated the notifications for messages, all of them, not only favourite contacts. That triggered that even emails vibrated.
Now seems to be working as usual!
