Yes, exactly.
but then you should have to be asked if to unlock by pin or by fingerprint. is that right?
No, once you’ve registered your fingerprint you can always* use it to unlock your phone. You can configure an alternative method to unlock the phone via PIN, pattern or password.
*) Fingerprint unlocking is not available directly after a restart of the phone or after a high number of failed attempts (you’ll need the other configured method - like e.g. PIN - in that moment)
hi budo, did you find a solution for your “double-pin” problem?
thanks, rudi
thank you, volker, I can see that more clearly now!
Yes. I switched the sims positions and then the problem went away. Very strange!
thanks for your answer.
unfortunately, changing my sim position did not solve this fastidious bug.
