As you can see from the attached image, my FP2 seems to have a damaged display on the RHS.
It has manifested itself in me not being able to press some on-screen buttons on the RHS of the screen. Using the Settings/Maintenance/Checkup/Drawing option I tried to draw diagonal lines, but from the image attached, you can see there is a band on the RHS of the screen where the screen is not working properly (it seems to skip to the RHS horizontally as you approach the edge).
I am assuming that this a new display screen will fix this ? I have ordered a new screen anyway as the phone is hard to use as it is. Would be interested in whether anyone thinks differently ?
