I am working in a environment with a lot of people around me, so it may be a little noisy sometimes. Every now and then I need to make a call. When I key in the number I get the beeps. Is there a way the I can disable those sounds, just those. I know I can use another audioprofile, but that is not what I want.I just want to disable the keysounds in the phoneapp (and that is the only place I hear them).
If you are using either the “General” or a custom profile you can choose whether to enable or disable the dial pad sound on that specific profile.
Go to Settings --> Audio profiles and tap the icon to the right of the profile you want to disable the dial pad sound for, then scroll down to the “System” section and uncheck “dial pad touch tones”.
Cheers
Thank you!!!
[Edited by moderator: Removed email content]
