Disable Camera button (lower one on right side of FP2)
Is there a way to deactivate the lower camera button on the FP2? It too often happens that when using the phone it accidentally is pushed and the camera starts. Next to that there is the option to use the power-on button for it by pushing it twice. (so actually the camera button is not required at all) I searched the forum but did not find a solution.
Regards,
Paul
I’m not sure whether this still works:
Based on the discussion in the topic linked below, it is/was possible to set it to ‘do nothing’
By the way, the (outer) camera button in the case rim can be physically removed with a little care without damaging it (thus allowing re-attaching it later). I would try to close the resulting gap with a bit of tape or otherwise though to avoid too much dust getting inside.
Thx. for the tip.
Rgds.,
Paul
I tried with Activity launcher (also described in an other topic) but that does not seem to work.
Rgds.,
Paul
