Xprivacy
[Xprivacy][1] is a #dic:floss::tag ([GNU GPL v3][3]) module for the #dic:xposed::tag Framework. It helps you prevent applications from leaking privacy-sensitive data by restricting permissions on an per-app basis.
If you buy a Pro key on https://www.xprivacy.eu/ you can even selectively hide individual contacts or accounts from any app (for example you can decide that person A is visible to Whatsapp and person B is not).
See also: [How to protect a bit of your privacy using XPrivacy][5]
