🇫🇷 🇬🇧 Default alarm sound isn't applied - when setting up a new alarm
Hello all! Thank you for this forum.
FR :
Problème : Lorsque je crée une nouvelle alarme, le son d’alarme défini par défaut n’est pas respecté.
  • Le son par dĂ©faut ne change pas dans les paramètre, mais la nouvelle alarme affiche et joue un autre son.
  • Cet autre son est systĂ©matiquement CARBON, peu importe si le son dĂ©fini par dĂ©faut est un autre son natif ou un fichier audio tĂ©lĂ©chargĂ©.
FP5 5G,
OS Android par défaut, FP5.VT32.C.116.20260903
App Horloge, V9.1 (965977594)
MAJ OS et App effectuées
Cache vidé
Tel redémarré.
Merci pour votre temps !!!
____
EN :
Issue: When I create a new alarm, the default alarm sound setting is not applied.
  • The default sound setting remains unchanged in the settings, but the new alarm displays and plays a different sound.
  • This other sound is consistently “CARBON,” regardless of whether the default sound is another built-in sound or a downloaded audio file.
FP5 5G,
Stock Android OS, FP5.VT32.C.116.20260903
Clock app, V9.1 (965977594)
OS and app updated
Cache cleared
Phone restarted.
Thanks for your time!!!
Hi @A.Xylo , welcome to the forum! :smiley: Thank you for sharing your issue in detail.
After a quick look into Fairphone’s public issue tracker, I could not find this alarm problem. As it says on the page:
it may be a lower-priority issue, an unconfirmed hardware problem, or one we haven’t received enough reports on yet.
I’m going to try to recreate your issue on my Fairphone 5 today and let you how it went.
If more people notice the same thing on their devices and we don’t find a clear cause or solution, I think you should reach out to Fairphone’s Customer Support using their contact form. As they say:
This is the primary way we collect and evaluate bug reports for prioritization and resolution.
Have a nice day :slight_smile:
Ok thanks @diogurt , I would!
Thank u for your time and your tests.
Da vedere!
Have a nice day too!
Hello again @A.Xylo I tested creating new alarms under different circumstances but I could not replicate the issue.
In my case, the Default alarm sound I select in Settings > Sound & vibration > Default alarm sound is the sound that new alarms use.
When you say:
Do you mean that your new alarm sound shows “Carbon” as the selected sound? If so, what happens when you select a new sound for that specific alarm?
I remembered that you can Send feedback to Google via the 3-dot menu on the Clock app. Maybe it is worth a shot.
My device is a FP5 5G running build number is FP5.VT32.C.116.20260903
The Clock app version is 9.1 (965977594)
Hi @diogurt !
Thx for your tests.
Yes, the new alarm always displays and plays “CARBON,” regardless of whether the default sound is another built-in sound or a downloaded audio file.
Just as if my default choice was CARBON (who on earth would do that haha.)
So I end up with creating an alarm set up on the CARBON sound but I still can change the sound on “X” (every choice works) and at this point this alarm will always respect this choice (display on screen, AND play it in the morning.)
To summary : this is only a malfunction of the “default choice” option. Not so annoying.
  • We share both the same phone, built, and ClockApp version.
  • You’re right. I just sent feedback to Google following ur advice.
  • I’ll feedback this to Fairphone too, just the time for me to find my proof of purchase, necessary when requesting a diagnosis.
Anyway, thank you again for your time.
