Can beta testers count on a launch in the next days ?
They can count on it from 5 minutes ago ![]()
Yes, i saw that. Next month iâll ask sooner ![]()
As of today, my FP4 has Security updates until 5.08.2023
This is incredibly bad and negligent!
Other current phones have updates until 01.11.2023 by now.
I donât even want to start looking for how many dangerous security gaps are open due to the lack of updates. The secret services and hackers are delighted.
I thougt, I bought a modern phone with in time updates.
(My build nr. is FP4.TP1V.C.073.20230905 and no updates are offered.)
Have you manually searched for updates? With Wifi, or with mobile data? What is your provider? Have you set-up anything blocking internet access? Have you checked/searched without SIM? Did you try to clear cache/storage of the updated App?
I always search manually because I am eagerly waiting for the updates.
I only search for updates when Iâm on my home wifi.
Provider: yesss (A1 network) in Austria.
I do not remove SIM - why should I?
No cache cleared until now.
I see its not the first time you get updates delayed. did you ever contact support, to see if there is any OTA glitch with your IMEI? Maybe its for whatever reason connected to the provider?
because
While there is little to nothing that can be done (by us) about the zero click that this thread is ultimately about, there are ways of mitigating the fact that youâre behind on updates in other ways.
The most obvious risk is your browser. If you use a browser that supports disabling JIT youâre ultimately a lot more secure.
The downside? The only browser that seems to support that on Android, while also being up to date, is Cromite, which has to be downloaded from F-Droid rather than the Play Store.
But if youâve got 5 min to spare, you may want to check it out.
Maybe someone should make a dedicated security thread?
I tried it now. Switched off SIM and checked for Update.
âYour system is up to dateâ
Deactivating the SIM did not help.
Furthermore, I did not find any blocking messages for my FP4 in my local pihole.
Is it possible, to manually download the update on phone und start it?
no not without unlocking the bootloader and loosing all data.
so back to:
Edit: no idea if this helps or not
Thanks for the advice but pihole isnât to blame.
I checked it twice, thereâs nothing blocked, when update runs.
Which support team should I contact? FP support or the providerâs support?
I would try FPâs support first.
Or just use Firefox with the NoScript add-on. Caveat: Itâs for techies only, because it preemptively breaks all internet, and you have to fix it manually, site by site!.. (The point being that this also breaks all malevolent scripts: You only run those you trust.)
Firefox doesnât have the same type of isolation as Chromium based browsers, unfortunately.
Also, Iâve tried using NoScript in the past. It almost drove me insane.
Why, itâs pretty straightforward IMHO. Tedious, especially when youâre new to it, but after a while itâs not more hassle than changing gears in your car: You have a list of script domains which are always blocked (like ads and trackers), and you have to temporarily allow scripts of websites you (need to) trust. Or even whitelist them if you use them frequently. For instance, on this page Iâve whitelisted âfairphone[.]comâ, but âgoogletagmanager[.]comâ is always blacklisted. ![]()
Thatâs all there is to it. Obviously you need to know what âsomestrangename[.]comâ is supposed to be, and if blocking it will break the page, but after some trial and error you learn.
I donâ't know about Chromeâs supposed superior capacities, all I know is it comes from Google, and thus is entirely and exclusively designed to monetize its users.
I do have a flavor if Chromium installed, because some incompetent web designers create Chrome-only websites (who remembers âBest viewed in Internet Explorerâ?..), but Iâve been using Firefox for many, many years, actually since Netscape went the way of the Dodo, killed by an greedy and ambitious Microsoft⌠Nowadays Google has replaced Microsoft in trying to control Internet commerce (billions of âŹâŚ), and I donât like monopolies and monocultures. Everybody already forgot the time some 20 years ago when about any installer (Adobe updatesâŚ) also silently installed Chrome, secretly replacing your default browser. I must have uninstalled Chrome over a hundred times⌠![]()
So no, for me Chrome/-ium is a dirty word.
/rant
The issue is that I want to visit a lot of different sites every day and adding every single issue site to NoScript just wasnât all that exciting to me. It took me out of the flow for what was ultimately, in my eyes, a minor security increase.
On my Windows computer I already run Waterfox in Sandboxie with settings so hardened that Waterfox can barely access anything outside of the Waterfox profile folder. For shady sites I run Mullvad Browser in Windows Sandbox, also hardened.
On my Fairphone however, I donât have an extra sandbox or anything, but Cromite has plenty of hardening that most other mobile browsers lack.
I get it. Being forced to use Chromium blows. But IMO both Brave and Cromite are pretty great mobile browsers. Brave is very plug and play and comes with HTTPS Everywhere and AdBlock. Cromite comes with JIT being disabled by default, increasing the security.
Personally, Iâm hoping for Firefox to soon add similar sandboxing to Chromium, as I really, really want Firefox to succeed.
But IMO, if you donât want to use NoScript or something similar, Cromite is the best security option for Android today.
Well, itâs just two clicks, but I understand it might get tedious. ![]()
I donât do much sightseeing, I mostly have a fixed number of sites I visit. ![]()
Well, Firefox too (not Adblock, but a similar feature, although I prefer using uBlock Origin. Why settle for less?)âŚ
How is that different from NoScript? (Genuine question) ![]()
That should break all and every website, forcing you to manually allow specific scripts to make it work again. Just like NoScript, no?
JIT doesnât disable the scripting, it is just a safer, but slower way to run it.
The JIT engine is very complex program and also has to set memory writable and executable which prevents use of certain security features and makes exploits easier.
In nearly every Chromium release, there are JIT related security fixes.
I cover which browsers do and donât have it enabled here: Browsers - DivestOS Mobile
Android also uses a JIT to run apps as part of ART, which systems use it are covered here: Comparison of Android ROMs
You should not use HTTPS Everywhere (even EFF says so), both Chromium and Firefox have these built in now.
And uBlock Origin is superior to any other blocker.
(I understand this is in context of Brave having those as features, just should be noted)
Cromite does not have CFI enabled like Vanadium & Mulch, and often is a few days to a week behind them too.
So for security wise, Vanadium and then Mulch are the best.
For privacy, I still recommend my Mull or Tor Browser.
Yeah I saw that on GitHub just now. Sadly, Daniel Micay decided to be a dick as usual instead of letting the Cromite developer use the Vanadium patch for it. Oh well.
Iâll definitely check out Mulch though. Any plans of adding an adblocker for it? The only thing I value more than the integrity of my device is the integrity of my brain. And thatâs sadly under attack daily by sleezy ads everywhere.
