Damaged charging socket
Hi, my FP3 charging socket is damaged so it’s very hard to get the cable to fit, it charges very slowly and stops charging at any moment. I’d like to repair it but it no longer seems possible as new charging sockets for FP3 don’t appear to be available. Any ideas?
Calling @Antoine from Paris.
the bottom module is available
Thanks!! I didn’t realise that was what was needed (feeling a bit stupid now!)
no need to feel stupid its not very obvious from the shop in my eyes, in german it only say “it gives your a FP a voice”
@Fairphone_CM a feedback about the Homepage… when you scroll further down “the tab description” is not really visible and its quite easy to overlook it
To minimise the wear and tear you could use a magnectic cable. I use them from Netdot. Make sure the cable is for charging and data.
thanks @yvmuell , I’ve forwarded the feedback to our website team! :folded_hands:t2:
Hello @alino, I have some refurbished modules or second hand ones for cheaper if you’re interested!
