Cracked screen protector
Hi there,
I’m using the blue light filter screen protector on my FP3+ and am very happy with it. It actually already saved the screen from an accident with a big hotel key and now the protector is broken with some long cracks running over the display. Can I just lift it off with a thin tool or is there some kind of glue involved in keeping the protector in place on the screen?
Does anyone know when the FP3 screen protectors will be back in stock?
Kind regards
Rigol
Normally (just 5 Min ago I removed one) its no problem to remove screen protectors, however I never used the FP protectors. Did you ever try to use nightlight instead of a blue light filter? There are good and cheaper third party protectors available.
