Connect fairphone to Ethernet
I want to buy a Fairphone. Before I buy please could someone answer the following two questions?:
How can I connect the Fairphone to the internet via Ethernet cable instead of wifi? I have a Lighting to Ethernet adaptor – could I use that or some other adaptor?
I currently have an iphone 4S with a very long list of Contacts in the Address Book. How do I get all the contacts from the iphone on to the Fairphone? I have a bacup of the iPhone data on my Apple Macbook Pro laptop (May 2010 release). Perhaps I could transfer the contacts across from the bacup on the laptop?
Lightning is not supported as it is specific to Apple; instead the Fairphone supports USB OTG to connect various devices. You can find USB OTG ethernet adapters online; using an OTG cable to connect to a ‘normal’ USB device, would typically also work.
For your contacts, I’d recommend to open a new topic if you can’t find it anywhere else on the forum.
Hello
Some time ago I tested an USB RJ45 adapter, but it wasnt supported at the time :
You could be luckier now that several updates passed, or with different adapter brands/models
