Hey guys,
I’m looking for a detailed component plan for the FP2. Where can I find something like that? I like to know, where the other parts than replacable components, e.g. vibrating motor inbuilt.
Thanks a lot
Here is the a of modules and what they contain. More Info can be found on the iFixit teardown.
If you have a transparent cover or take off the cover you can see it. It’s between battery, speaker and extension port.
You can ask, but I assume you will not get one. So far there is not even a part list available.
