Any update on when the issue that the clock is reset every boot will be fixed? I located the problem, that Android fails to set the hardware clock (as the hardware clock is running from 01.01.1970) since you last removed the battery.
For other: If you run the command “hwclock” you get the hardware clock time, which is set to the system/software clock every boot. If you run “hwclock -w” (which should set the hardware clock from the system clock), you get an error message.
Cheers.
A post was merged into an existing topic: FP Open OS: Clock resets after reboot
