Just added my chargers.
I am also quite curious what causes these problems. Fortunately for me several devices I tried worked flawlessly.
Just another comment: I think that the link to the survey is very well hidden here in the thread, maybe it can be made more visible, e.g. by putting a post on the top of this thread that asks people with (or without) problems to fill out the survey?
Anyhow, good luck finding the root of this problem!
I have the same problem as @FeuRenard. A few seconds charging, then not charging on my laptop. When the FP2 is off, it is charging without problems using the same USB2.0 socket and the same cable.
In my office (desktop) computer it charges correctly, but very slow (about 6-8 hours for a full charge from 0%).
I have to try different on my wall and car chargers, to be sure that they are ok. I will come back with more information about chargers and cables when I have tested them.
So, my very first post here in the forum!
I had the same issue with my old charger, now I bought this one link to Amazon from Anker and it is working for me.
This may be related, maybe not. When my phone is turned off, fully charged (500 mA-charger) and the notification LED is green (!), the area of the camera module gets quite hot, about 40 C.
I have the 4-port Version with an Anker cable. My FP2 is successfully charged with them. Well, it makes some strange noises when a device is plugged on.
My FP wonāt charge as well.
Because i havenāt owned a micro USb Carger allready i bought this charger https://shop.mediamarkt.ch/de/handy-navigation/zubehoer/ladetechnik/ladekabel/micro-usb/cellularline-usb-charger-compact-kit-schwarz/idpt88sheera
It has exactly the stats FP recomends but it wont charge a bit. Itās even more strange that i charged it overnight. at first it looked good (it shows the charging screen and told the akku is at about 30 %) but in the morning nithing worked and now when i try to charge it it sas it has 0% battery. so it lost Battery while charging. WTF
Did anyone else use this charger and it works? Has someone the same problem?
Thanks alot for your help
Itās realy not easy to find a working charger. The shop assistant in my local electronic shop was so kind, to try out 10 different ones to find one thatās commpatible with my FP2.
Edit: To start the charging process, I have to turn off the phone first. And then plug in the charger. Once the charging has startet, I can turn the phone on.
Hi, my FP2 charges most of the time, but it has happened twice that it started charging in the evening when I plugged in the charger (once with the phone turned off, seeing the animation of being charged and once while the phone was still turned on, seeing the lightning bolt in the battery icon) and that it had discharged the next morning. The energy level was over 20% both times I had plugged it in and completely zero (when I had charged the phone while it had been turned off; it wouldnāt turn on and I could only see the red led blink) and 7% (when I had charged the phone while it hadnāt been turned off). The second time I used the battery of my boyfriends FP2 (because he is not yet using his FP2). So it doesnāt seem to be an exclusive problem of my particular battery.
I have also sent a question to Support, but does anybody recognise these strange troubles with charging and does anyone know the origin of this problem and how it can be avoided? (I am afraid it will ruin my battery). Thanks in advance!
Could you, please, answer to my request #82397 ⦠(2 weeks agoā¦)
Iāve a big problem cause i canāt use my FP2ā¦
When i get my new FP2 i could not load the battery.
I bought a new shorter cable and now, (i suppose the battery is empty), my FP2 canāt start (looping in Welcome to fairphone, vibrator, black screen⦠so oneā¦)
what can i do ? Send it back ?
If you mean to address the FP people, please be aware they donāt read all topics on this community forum! If you want to communicate to FP directly, best update your request or try to call them (phone number at the bottom of this page)
Hello
i had the same problem and bought allready 2 new data-Cables with no success(I could load it once and was also able to send data but a few days later i could not anymore and bought another Cable)
MY SOLUTION was RESET (Restore to Previous settings) Sichern und zurücksetzen the phone and now it does work again. MAKE sure you SAVE your DATA first otherwise they get lost.
I got this cabel (http://www.amazon.de/Orig-Ladeadapter-Sony-Ericsson-AN400-Datenkabel/dp/B005FO0VWI) and it works jst fine.
i hope this helps everyone with problems. I was really anoyed that my freshly bought charger didenāt work and i still think it is a huge fail of FP to not at least make a list with working chargers/cables. If they donāt sell a charger with it i think it is their duty to do so.
This sounds like the issue I had with a fully drained battery.
At the advise of support, I did as follows: removed the battery, added charging cable. This got me in the loop you describe (Welcome to fairphone, vibrate, black screen).
I left the phone like that for minutes (5-10?). Then I inserted the battery. It appeared nothing happened for minutes (again 5-10?) and then the phone suddenly started to boot and showed a fully drained battery, which then slowly commenced charging.
Hi Charlotte
My sister explained the same behavior to me. Instead of charging her phone got discharged as wellā¦
Now sheās trying to find a solution.
Iāll tell you when we know more.
This charging problem is a really bad thing for the Fairphone crewā¦
I tested 4 different chargers, all with not integrated cables.
For me the cable made no difference at all, only the charger mattered.
So to be clear: The same cable always works with one charger and never works with the other.
If the FP2 was on or off made no difference to me.
These chargers did not work:
Ktec P4113 (came with a Medion tablet) Input 0.5A Output 5.0V 2.0A
Ibo_Store model MB06031995 (ebay) I 0.15A O 5.0V 1.0A
Both chargers work well with other devices.
These chargers did work:
Goobay Mod 44004 Order-No 508-72 (bought from Mercateo) Input 0.15A Output 5.25V 1A
Apple Flextronics Model A1300 (came with iPhone) I 0.15A O 5.0V 1.0A
The Apple looks (apart from being white) identical to the Ibo_Store and has identical values.
I could also charge with a W7 Laptop and a Linux laptop.
