I think you refer to a problem which was raisen already some times before in the forum (see below).
Unfortunately it could be, that the USB connector is really broken and unusable.
Only solution is to change the motherboard or solder a new USB connector, which is a quite delicate work without beeing expert (see links).
If you don’t want to make it yourself you should contact support directly and ask after warranty repair.
