Case for the Fairphone not grippy
Hello, I’ve been using my new Fairphone 6 for a few days now and I’m thrilled! I ordered the matching case at the same time, and it looks really good. However, I think the case is not grippy: somehow, you always feel like the device is going to slip out of your hand at any moment. Does anyone have a solution for this?
Welcome to the Community Forum :waving_hand:
Have you considered the finger loop accessory?
https://shop.fairphone.com/shop/fairphone-6-finger-loop-1896
Okay, that would be an alternative. However, it makes the device a bit thicker and does not necessarily protect it from falling when you take your smartphone out of your pocket, for example.
Assuming you are talking about the original FP case you can easily combine it with a finger loop assessory.
Edited to add that there’s a topic to discuss FP alternative cases as well
By the way, I’ve since bought the finger loop accessory. It makes the Fairphone much easier to grip, e.g. when picking it up from a tabletop, because the device now has a 3 mm gap between it and the surface. For me, it’s the ideal accessory. Thanks again for the tip!
