Hi folks,
I recently bought my FP5 and I love it!
But it seems I can’t install the latest eOS update (2.6.3). The download works, but when I click on Install nothing happens, no error, or else.
Current version is eOS 2.5-t-20244418446629-official-FP5.
Do I have to download it manually and if yes, where do I find the download, or do I have just wait for the official FP5 update?
Don’t know why Install does not work in your case.
But I can tell you that manual downloads can be found here:
https://ota.ecloud.global/official/FP5/
Still the version mentioned by you has a very weird number. 2.5 should be e-2.5-t-20241108446629-official-FP5.
Have you tried simply restarting it?
Did you try clearing the cache of the updater-app?
Thanks for your answers so far.
Yeah, I restarted the update process several times and re-downloaded the image with no luck.
Clearing the cache didn’t help
Thanks for the link, I’ll try it now. Regarding the number, probably just a typo =)
Didn’t work either.
Also, if I export the URL in the updater app, it seems to download the correct image: https://ota.ecloud.global/official/FP5/e-2.6.3-t-20241217455358-official-FP5.zip
I tried downloading the update and choose local update, but it always fails at the first step (preparing for first time boot).
I’ll write the FP support, maybe they can help and will update here.
Sorry to hear that nothing’s helping so far. You might also post your troubles on the eOS community forum.
I’d wait at least for the next eOS-Update which should be released in the next couple of days before trying out more drastic measures…
But just to be clear. You bought the FP5 pre-installed with eOS from Murena? If so they’re the ones who should fix it (instead of Fairphone).
I suppose you’ve already rebooted the entire device yet without further success, right?
Yes that’s what I mean with "restarting it (as in device). I realize now that I wasn’t specific enough.
Back in the days, after having finished installing the update (but not rebooting) all sorts of inconsistencies would appear. Sometimes available updates would disappear all together or was presented again as if installion hasn’t been started yet.
In every case the issue was resolved by “restarting the phone”.
This was the first thing I tried, also no success.
I bought the phone on fairphone.com, but yes, pre-installed with eOS.
Thing is, Murena states on their support page:
For issues with products purchased with other stores, please contact the Helpdesk of that store. For example, for phones with /e/OS purchased on Fairphone.com, please contact the Fairphone Helpdesk at https://support.fairphone.com
and the FP support page (https://support.fairphone.com/hc/en-us/articles/9979154556817-Google-free-Android) states:
To get support for /e/OS, you will have to contact Murena directly.
So this will be a responsibility ping-pong probably. I opened a ticket at the FP support, where I pointed that out, so lets see what they say.
I’ll try the eOS forum, too. Thanks for the link. Maybe the next release will help.
If nothing works, I’ll probably have to flash the newer image manually. But as far as I understood the regarding manual, unlocking the bootloader will erase all data on my phone. Luckily there’s not much on it, since it’s new, but still least favorite option.
Guess I have to wait for now. Thanks for your participation, I’ll keep you posted!
In this case, you need to install manually, I think. You can find the instructions here.
Let us know how it goes.
Tried to install the update manually with adb sideload
, again no luck
I opened a thread on the e/OS forum (see here).
main content of my initial post there
Latest thing I tried, was to install the update manually via recovery with adb sideload
, which also failed with the following error message:
Error applying update: 7 (ErrorCode::kInstallDeviceOpenError)
ERROR: recovery: Error in /sideload/package.zip (status 1)
To be sure I tried it with different cables.
Do I need a unlocked bootloader for applying an update via adb sideload
Unfortunately the body content length here is limited, so I can’t upload the full recovery.log
here.
This should be the entries regarding the update process:
recovery.log
[ 8.614288] Now send the package you want to apply
[ 8.614289] to the device with "adb sideload <filename>"...
[ 8.660811] minadbd I 01-14 19:37:43 434 435 usb_ffs.cpp:275] opening control endpoint /dev/usb-ffs/adb/ep0
[ 8.661532] minadbd I 01-14 19:37:43 434 435 usb.cpp:152] UsbFfsConnection constructed
[ 8.661765] minadbd I 01-14 19:37:43 434 436 usb.cpp:259] UsbFfs-monitor thread spawned
[ 8.663412] minadbd I 01-14 19:37:43 434 436 usb.cpp:298] USB event: FUNCTIONFS_BIND
[ 9.364640] minadbd I 01-14 19:37:43 434 436 usb.cpp:298] USB event: FUNCTIONFS_ENABLE
[ 9.364704] minadbd I 01-14 19:37:43 434 441 usb.cpp:405] UsbFfs-worker thread spawned
[ 9.396141] minadbd I 01-14 19:37:43 434 434 adb.cpp:171] UsbFfs: already offline
[ 9.396152] minadbd I 01-14 19:37:43 434 434 adb.cpp:388] authentication not required
[ 12.803486] minadbd I 01-14 19:37:47 434 452 minadbd_services.cpp:111] sideload-host file size 1588718610, block size 65536
[ 13.803820] unknown fuse request opcode 2016
[ 13.804130] W:Failed to read /sys/class/thermal/thermal_zone9/temp: Invalid argument
[ 13.806213] W:Failed to read /sys/class/thermal/thermal_zone8/temp: Invalid argument
[ 13.813386] W:Failed to read /sys/class/thermal/thermal_zone71/temp: Invalid argument
[ 13.813474] W:Failed to read /sys/class/thermal/thermal_zone7/temp: Invalid argument
[ 13.814920] W:Failed to read /sys/class/thermal/thermal_zone6/temp: Invalid argument
[ 13.815233] W:Failed to read /sys/class/thermal/thermal_zone5/temp: Invalid argument
[ 13.815545] W:Failed to read /sys/class/thermal/thermal_zone4/temp: Invalid argument
[ 13.815677] W:Failed to read /sys/class/thermal/thermal_zone36/temp: Invalid argument
[ 13.815887] W:Failed to read /sys/class/thermal/thermal_zone3/temp: Invalid argument
[ 13.816203] W:Failed to read /sys/class/thermal/thermal_zone2/temp: Invalid argument
[ 13.816282] W:Failed to read /sys/class/thermal/thermal_zone18/temp: Invalid argument
[ 13.816416] W:Failed to read /sys/class/thermal/thermal_zone15/temp: Invalid argument
[ 13.816477] W:Failed to read /sys/class/thermal/thermal_zone14/temp: Invalid argument
[ 13.816534] W:Failed to read /sys/class/thermal/thermal_zone13/temp: Invalid argument
[ 13.816588] W:Failed to read /sys/class/thermal/thermal_zone12/temp: Invalid argument
[ 13.816641] W:Failed to read /sys/class/thermal/thermal_zone11/temp: Invalid argument
[ 13.816697] W:Failed to read /sys/class/thermal/thermal_zone10/temp: Invalid argument
[ 13.816751] W:Failed to read /sys/class/thermal/thermal_zone1/temp: Invalid argument
[ 13.816810] W:Failed to read /sys/class/thermal/thermal_zone0/temp: Invalid argument
[ 13.816831] I:current maximum temperature: 39000
[ 13.816843] Supported API: 3
[ 13.836120] Finding update package...
[ 13.869539] I:Update package id: /sideload/package.zip
[ 13.969912] I:1 key(s) loaded from /system/etc/security/otacerts.zip
[ 13.969940] Verifying update package...
[ 14.023199] I:comment is 1587 bytes; signature is 1569 bytes from end
[ 28.825253] scudo: Stats: SizeClassAllocator64: 261M mapped (0M rss) in 21848 allocations; remains 4575
[ 28.825284] 00 ( 64): mapped: 256K popped: 1001 pushed: 923 inuse: 78 total: 104 rss: 0K releases: 0 last released: 0K region: 0x72c446d000 (0x72c4462000)
[ 28.825289] 01 ( 32): mapped: 256K popped: 39 pushed: 0 inuse: 39 total: 52 rss: 0K releases: 0 last released: 0K region: 0x72d4465000 (0x72d4462000)
[ 28.825314] 02 ( 48): mapped: 256K popped: 8229 pushed: 8177 inuse: 52 total: 104 rss: 0K releases: 0 last released: 0K region: 0x72e446f000 (0x72e4462000)
[ 28.825319] 03 ( 64): mapped: 256K popped: 4147 pushed: 4082 inuse: 65 total: 104 rss: 0K releases: 0 last released: 0K region: 0x72f446c000 (0x72f4462000)
[ 28.825323] 04 ( 80): mapped: 256K popped: 26 pushed: 0 inuse: 26 total: 52 rss: 0K releases: 0 last released: 0K region: 0x7304467000 (0x7304462000)
[ 28.825388] scudo: 05 ( 96): mapped: 256K popped: 13 pushed: 0 inuse: 13 total: 52 rss: 0K releases: 0 last released: 0K region: 0x731446c000 (0x7314462000)
[ 28.825396] 06 ( 112): mapped: 256K popped: 26 pushed: 0 inuse: 26 total: 52 rss: 0K releases: 0 last released: 0K region: 0x7324472000 (0x7324462000)
[ 28.825400] 07 ( 144): mapped: 256K popped: 39 pushed: 0 inuse: 39 total: 52 rss: 0K releases: 0 last released: 0K region: 0x7334466000 (0x7334462000)
[ 28.825404] 08 ( 176): mapped: 256K popped: 13 pushed: 0 inuse: 13 total: 52 rss: 0K releases: 0 last released: 0K region: 0x734446b000 (0x7344462000)
[ 28.825408] 10 ( 224): mapped: 256K popped: 26 pushed: 0 inuse: 26 total: 52 rss: 0K releases: 0 last released: 0K region: 0x7364463000 (0x7364462000)
[ 28.825466] scudo: 11 ( 288): mapped: 256K popped: 13 pushed: 0 inuse: 13 total: 52 rss: 0K releases: 0 last released: 0K region: 0x7374470000 (0x7374462000)
[ 28.825474] 12 ( 352): mapped: 256K popped: 26 pushed: 0 inuse: 26 total: 52 rss: 0K releases: 0 last released: 0K region: 0x738446a000 (0x7384462000)
[ 28.825478] 13 ( 448): mapped: 256K popped: 26 pushed: 0 inuse: 26 total: 52 rss: 0K releases: 0 last released: 0K region: 0x7394470000 (0x7394462000)
[ 28.825482] 15 ( 800): mapped: 256K popped: 10 pushed: 0 inuse: 10 total: 40 rss: 0K releases: 0 last released: 0K region: 0x73b4469000 (0x73b4462000)
[ 28.825485] 16 ( 1104): mapped: 256K popped: 7 pushed: 0 inuse: 7 total: 28 rss: 0K releases: 0 last released: 0K region: 0x73c446f000 (0x73c4462000)
[ 28.825543] scudo: 17 ( 1648): mapped: 256K popped: 4 pushed: 0 inuse: 4 total: 16 rss: 0K releases: 0 last released: 0K region: 0x73d4470000 (0x73d4462000)
[ 28.825550] 20 ( 3120): mapped: 256K popped: 2 pushed: 0 inuse: 2 total: 8 rss: 0K releases: 0 last released: 0K region: 0x7404465000 (0x7404462000)
[ 28.825555] 21 ( 4112): mapped: 256K popped: 4 pushed: 0 inuse: 4 total: 4 rss: 0K releases: 0 last released: 0K region: 0x7414468000 (0x7414462000)
[ 28.825558] 27 ( 16400): mapped: 256K popped: 4104 pushed: 4091 inuse: 13 total: 15 rss: 0K releases: 28 last released: 44K region: 0x747446a000 (0x7474462000)
[ 28.825562] 28 ( 18448): mapped: 256K popped: 1 pushed: 0 inuse: 1 total: 4 rss: 0K releases: 0 last released: 0K region: 0x7484472000 (0x7484462000)
[ 28.825617] scudo: 30 ( 29456): mapped: 256K popped: 1 pushed: 0 inuse: 1 total: 4 rss: 0K releases: 0 last released: 0K region: 0x74a4464000 (0x74a4462000)
[ 28.825625] F 32 ( 65552): mapped: 261888K popped: 4091 pushed: 0 inuse: 4091 total: 4091 rss: 0K releases: 0 last released: 0K region: 0x74c4467000 (0x74c4462000)
[ 28.825635] Scudo OOM: The process has exhausted 256M for size class 65552.
[ 28.825639]
[ 104.469640] I:signature (offset: 5eb1e5f1, length: 61b): 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
[ 104.473668] I:whole-file signature verified against RSA key 0
[ 104.473697] Update package verification took 90.5 s (result 0).
[ 104.515430] Installing update...
[ 104.565687] I:old spl: 2024-10-05 new spl: 2024-12-05 CHECK passes
[ 104.565812] I:[libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
[ 104.581457] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:sideload_main.cc(193)] Update Engine Sideloading starting
[ 104.583149] update_engine_sideload I 01-14 19:39:18 648 648 fs_mgr_fstab.cpp:377] [libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
[ 104.587742] cutils-trace E 01-14 19:39:18 648 648] Error opening trace file: No such file or directory (2)
[ 104.587820] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:boot_control_android.cc(69)] Loaded boot control hidl hal.
[ 104.588018] libprocessgroup E 01-14 19:39:18 648 648 task_profiles.cpp:622] Failed to read task profiles from /etc/task_profiles.json
[ 104.588046] libprocessgroup E 01-14 19:39:18 648 648 task_profiles.cpp:595] Loading /etc/task_profiles.json for [648] failed
[ 104.588084] libprocessgroup W 01-14 19:39:18 648 648 task_profiles.cpp:842] Failed to find OtaProfiles task profile: No such file or directory
[ 104.588273] update_engine_sideload E 01-14 19:39:18 648 648] [ERROR:update_attempter_android.cc(950)] prefs_->GetInt64(kPrefsPreviousSlot, &previous_slot) failed.
[ 104.588299] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:update_attempter_android.cc(196)] OTAResult::NOT_ATTEMPTED
[ 104.588475] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:update_attempter_android.cc(203)] Skip ScheduleCleanupPreviousUpdate in sideload because ApplyPayload will call it later.
[ 104.588548] update_engine_sideload E 01-14 19:39:18 648 648 snapshot.cpp:2782] Open failed: /metadata/ota: No such file or directory
[ 104.588646] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:update_attempter_android.cc(322)] Using this install plan:
[ 104.588684] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:install_plan.cc(80)] InstallPlan:
[ 104.588688] type: new_update
[ 104.588691] version:
[ 104.588693] source_slot: A
[ 104.588694] target_slot: B
[ 104.588696] initial url: file:///sideload/package.zip
[ 104.588697] hash_checks_mandatory: true
[ 104.588698] powerwash_required: false
[ 104.588699] switch_slot_on_reboot: true
[ 104.588700] run_post_install: true
[ 104.588701] is_rollback: false
[ 104.588702] rollback_data_save_requested: false
[ 104.588703] write_verity: true
[ 104.588704] Payload: 0
[ 104.588705] urls: ()
[ 104.588706] size: 1588711545
[ 104.588707] metadata_size: 157728
[ 104.588708] metadata_signature:
[ 104.588709] hash: AA9E08E67709A746D3585CC18E040379CAFDC3F38E92AA23111F60F586A9579A
[ 104.588710] type: unknown
[ 104.588711] fingerprint:
[ 104.588712] app_id:
[ 104.588713] already_applied: false
[ 104.588756] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:postinstall_runner_action.cc(96)] postinstall mount point: /postinstall
[ 104.588785] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:metrics_utils.cc(318)] Number of Reboots during current update attempt = 0
[ 104.588821] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:metrics_utils.cc(326)] Payload Attempt Number = 1
[ 104.588882] __bionic_open_tzdata: couldn't find any tzdata when looking for GMT!
[ 104.588912] __bionic_open_tzdata: couldn't find any tzdata when looking for posixrules!
[ 104.588934] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:metrics_utils.cc(343)] Update Monotonic Timestamp Start = 1/1/1970 0:01:46 GMT
[ 104.588957] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:metrics_utils.cc(352)] Update Boot Timestamp Start = 1/1/1970 0:01:46 GMT
[ 104.588973] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:update_attempter_android.cc(840)] Clearing update complete marker.
[ 104.588991] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:update_attempter_android.cc(720)] Scheduling an action processor start.
[ 104.589033] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:action_processor.cc(51)] ActionProcessor: starting UpdateBootFlagsAction
[ 104.589052] update_engine_sideload I 01-14 19:39:18 648 648] [INFO:update_boot_flags_action.cc(45)] Marking booted slot as good.
[ 104.641653] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:action_processor.cc(116)] ActionProcessor: finished UpdateBootFlagsAction with code ErrorCode::kSuccess
[ 104.641707] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:action_processor.cc(143)] ActionProcessor: starting CleanupPreviousUpdateAction
[ 104.641750] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:cleanup_previous_update_action.cc(149)] Starting/resuming CleanupPreviousUpdateAction
[ 104.641842] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:cleanup_previous_update_action.cc(189)] Boot completed, waiting on markBootSuccessful()
[ 104.642053] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr_fstab.cpp:377] [libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
[ 104.643399] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:331] [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[ 104.648280] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:226] [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=0: Success
[ 104.649635] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:180] [libfs_mgr]umount_retry(): unmount(/metadata) succeeded
[ 104.649753] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:242] [libfs_mgr]Not running /system/bin/e2fsck on /dev/block/sda15 (executable not in system image)
[ 104.650587] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:331] [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[ 104.651041] update_engine_sideload E 01-14 19:39:19 648 648 fs_mgr.cpp:512] [libfs_mgr]Unable to enable ext4 verity on /dev/block/by-name/metadata because /system/bin/tune2fs is missing
[ 104.652653] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:838] [libfs_mgr]__mount(source=/dev/block/by-name/metadata,target=/metadata,type=ext4)=0: Success
[ 104.653590] update_engine_sideload W 01-14 19:39:19 648 648 snapshot.cpp:247] Cannot read /metadata/ota/snapshot-boot: No such file or directory
[ 104.653633] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2196] Not booting from new slot. Will not mount snapshots.
[ 104.653681] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:cleanup_previous_update_action.cc(240)] Snapshot devices are not created
[ 104.653741] update_engine_sideload I 01-14 19:39:19 648 648 snapshot_stats.cpp:37] Read merge statistics file failed: No such file or directory
[ 104.654172] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:cleanup_previous_update_action.cc(261)] Waiting for any previous merge request to complete. This can take up to several minutes.
[ 104.654463] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:1047] CheckMergeState for snapshots returned: 1
[ 104.654513] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:1019] ProcessUpdateState handling state: 1
[ 104.654557] update_engine_sideload E 01-14 19:39:19 648 648] [ERROR:cleanup_previous_update_action.cc(308)] Previous update has not been completed, not cleaning up
[ 104.654604] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:cleanup_previous_update_action.cc(130)] Stopping/suspending/completing CleanupPreviousUpdateAction
[ 104.654719] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:cleanup_previous_update_action.cc(472)] Skip reporting merge stats in recovery.
[ 104.658524] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:cleanup_previous_update_action.cc(130)] Stopping/suspending/completing CleanupPreviousUpdateAction
[ 104.658575] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:action_processor.cc(116)] ActionProcessor: finished CleanupPreviousUpdateAction with code ErrorCode::kSuccess
[ 104.658620] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:action_processor.cc(143)] ActionProcessor: starting InstallPlanAction
[ 104.658670] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:action_processor.cc(116)] ActionProcessor: finished InstallPlanAction with code ErrorCode::kSuccess
[ 104.658712] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:action_processor.cc(143)] ActionProcessor: starting DownloadAction
[ 104.658790] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:install_plan.cc(80)] InstallPlan:
[ 104.658797] type: new_update
[ 104.658801] version:
[ 104.658805] source_slot: A
[ 104.658808] target_slot: B
[ 104.658821] initial url: file:///sideload/package.zip
[ 104.658826] hash_checks_mandatory: true
[ 104.658829] powerwash_required: false
[ 104.658832] switch_slot_on_reboot: true
[ 104.658836] run_post_install: true
[ 104.658839] is_rollback: false
[ 104.658842] rollback_data_save_requested: false
[ 104.658845] write_verity: true
[ 104.658849] Payload: 0
[ 104.658852] urls: ()
[ 104.658855] size: 1588711545
[ 104.658858] metadata_size: 157728
[ 104.658861] metadata_signature:
[ 104.658865] hash: AA9E08E67709A746D3585CC18E040379CAFDC3F38E92AA23111F60F586A9579A
[ 104.658868] type: unknown
[ 104.658871] fingerprint:
[ 104.658874] app_id:
[ 104.658878] already_applied: false
[ 104.658919] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:download_action.cc(86)] Marking new slot as unbootable
[ 104.715233] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:multi_range_http_fetcher.cc(45)] starting first transfer
[ 104.715286] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:multi_range_http_fetcher.cc(74)] starting transfer of range 3706+1588711545
[ 104.833293] unknown fuse request opcode 2016
[ 104.836490] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(113)] Completed 0/? operations, 16384/1588711545 bytes downloaded (0%), overall progress 0%
[ 104.837323] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(344)] Manifest size in payload matches expected value from Omaha
[ 104.837360] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(887)] Verifying using certificates: /system/etc/security/otacerts.zip
[ 104.838981] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(925)] Detected a 'full' payload.
[ 104.839051] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] abl does't have version, skipping downgrade check.
[ 104.839076] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] aop does't have version, skipping downgrade check.
[ 104.839098] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] bluetooth does't have version, skipping downgrade check.
[ 104.839139] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] cpucp does't have version, skipping downgrade check.
[ 104.839164] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] devcfg does't have version, skipping downgrade check.
[ 104.839183] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] dsp does't have version, skipping downgrade check.
[ 104.839202] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] dtbo does't have version, skipping downgrade check.
[ 104.839221] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] featenabler does't have version, skipping downgrade check.
[ 104.839239] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] hyp does't have version, skipping downgrade check.
[ 104.839258] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] imagefv does't have version, skipping downgrade check.
[ 104.839277] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] keymaster does't have version, skipping downgrade check.
[ 104.839296] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] modem does't have version, skipping downgrade check.
[ 104.839315] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] multiimgoem does't have version, skipping downgrade check.
[ 104.839356] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] qupfw does't have version, skipping downgrade check.
[ 104.839378] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] shrm does't have version, skipping downgrade check.
[ 104.839407] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] tz does't have version, skipping downgrade check.
[ 104.839426] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] uefisecapp does't have version, skipping downgrade check.
[ 104.839443] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] vbmeta does't have version, skipping downgrade check.
[ 104.839460] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] vbmeta_system does't have version, skipping downgrade check.
[ 104.839481] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] vendor_boot does't have version, skipping downgrade check.
[ 104.839499] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] xbl does't have version, skipping downgrade check.
[ 104.839517] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(996)] xbl_config does't have version, skipping downgrade check.
[ 104.840941] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(736)] Preparing partitions for new update. last hash = , new hash = qp4I5ncJp0bTWFzBjgQDecr9w/OOkqojER9g9YapV5o=7ohtl1Rfkt9sbdtcPzRIu9wAWEnkyWxJkfnOBNNz7G8=
[ 104.840981] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:delta_performer.cc(1273)] Resetting recorded hash for prepared partitions.
[ 104.841318] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr_fstab.cpp:377] [libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
[ 104.841647] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr_fstab.cpp:377] [libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
[ 104.843108] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:331] [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[ 104.844534] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:226] [libfs_mgr]check_fs(): mount(/dev/block/by-name/metadata,/metadata,ext4)=0: Success
[ 104.845306] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:180] [libfs_mgr]umount_retry(): unmount(/metadata) succeeded
[ 104.845368] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:242] [libfs_mgr]Not running /system/bin/e2fsck on /dev/block/sda15 (executable not in system image)
[ 104.845676] libc: Unable to set property "ro.boottime.init.fsck.metadata" to "2": error code: 0xb
[ 104.845923] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:331] [libfs_mgr]superblock s_max_mnt_count:65535,/dev/block/by-name/metadata
[ 104.845984] update_engine_sideload E 01-14 19:39:19 648 648 fs_mgr.cpp:512] [libfs_mgr]Unable to enable ext4 verity on /dev/block/by-name/metadata because /system/bin/tune2fs is missing
[ 104.847061] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr.cpp:838] [libfs_mgr]__mount(source=/dev/block/by-name/metadata,target=/metadata,type=ext4)=0: Success
[ 104.847278] libc: Unable to set property "ro.boottime.init.mount.metadata" to "1": error code: 0xb
[ 104.847600] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:dynamic_partition_control_android.cc(781)] Erasing AVB footer of system_other partition before update.
[ 104.847652] update_engine_sideload E 01-14 19:39:19 648 648 fs_mgr_fstab.cpp:706] [libfs_mgr]ReadFstabFromFile(): failed to read file: '/system/etc/fstab.postinstall': No such file or directory
[ 104.847678] update_engine_sideload W 01-14 19:39:19 648 648] [WARNING:dynamic_partition_control_android.cc(655)] Cannot read fstab from /system/etc/fstab.postinstall: No such file or directory (2)
[ 104.847697] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:dynamic_partition_control_android.cc(682)] AVB is not enabled on system_other. Skip erasing.
[ 104.847786] update_engine_sideload I 01-14 19:39:19 648 648 fs_mgr_fstab.cpp:377] [libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
[ 104.849110] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:dynamic_partition_control_android.cc(347)] Loaded metadata from slot A in /dev/block/bootdevice/by-name/super
[ 104.849415] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:227] Update has been initiated, now canceling
[ 104.849437] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:288] Removing all update state.
[ 104.849609] update_engine_sideload W 01-14 19:39:19 648 648 snapshot.cpp:247] Cannot read /metadata/ota/snapshot-boot: No such file or directory
[ 104.849631] update_engine_sideload W 01-14 19:39:19 648 648 snapshot.cpp:1945] Failed to get flashing status
[ 104.849654] update_engine_sideload W 01-14 19:39:19 648 648 snapshot.cpp:247] Cannot read /metadata/ota/snapshot-boot: No such file or directory
[ 104.849759] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot product_b
[ 104.849797] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot product_b in recovery.
[ 104.849856] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot system_b
[ 104.849892] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot system_b in recovery.
[ 104.849950] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot odm_b
[ 104.849984] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot odm_b in recovery.
[ 104.850040] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot system_ext_b
[ 104.850076] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot system_ext_b in recovery.
[ 104.850134] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot vendor_b
[ 104.850170] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot vendor_b in recovery.
[ 104.850610] update_engine_sideload E 01-14 19:39:19 648 648 image_manager.cpp:277] Cannot remove images backed by /data in recovery
[ 104.850636] update_engine_sideload E 01-14 19:39:19 648 648 image_manager.cpp:277] Cannot remove images backed by /data in recovery
[ 104.850656] update_engine_sideload E 01-14 19:39:19 648 648 image_manager.cpp:277] Cannot remove images backed by /data in recovery
[ 104.850672] update_engine_sideload E 01-14 19:39:19 648 648 snapshot.cpp:2001] Could not remove all snapshot artifacts
[ 104.850688] update_engine_sideload E 01-14 19:39:19 648 648 snapshot.cpp:291] Could not remove all snapshots
[ 104.850711] update_engine_sideload E 01-14 19:39:19 648 648] [ERROR:dynamic_partition_control_android.cc(966)] Cannot begin new update.
[ 104.850735] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:dynamic_partition_control_android.cc(522)] PrepareSnapshotPartitionsForUpdate failed in recovery. Attempt to overwrite existing partitions if possible
[ 104.850768] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:227] Update has been initiated, now canceling
[ 104.850787] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:288] Removing all update state.
[ 104.850826] update_engine_sideload W 01-14 19:39:19 648 648 snapshot.cpp:247] Cannot read /metadata/ota/snapshot-boot: No such file or directory
[ 104.850846] update_engine_sideload W 01-14 19:39:19 648 648 snapshot.cpp:1945] Failed to get flashing status
[ 104.850868] update_engine_sideload W 01-14 19:39:19 648 648 snapshot.cpp:247] Cannot read /metadata/ota/snapshot-boot: No such file or directory
[ 104.850929] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot product_b
[ 104.850960] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot product_b in recovery.
[ 104.851019] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot system_b
[ 104.851058] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot system_b in recovery.
[ 104.851115] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot odm_b
[ 104.851149] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot odm_b in recovery.
[ 104.851203] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot system_ext_b
[ 104.851236] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot system_ext_b in recovery.
[ 104.851290] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot vendor_b
[ 104.851323] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:709] Skipping delete of snapshot vendor_b in recovery.
[ 104.851389] update_engine_sideload E 01-14 19:39:19 648 648 image_manager.cpp:277] Cannot remove images backed by /data in recovery
[ 104.851412] update_engine_sideload E 01-14 19:39:19 648 648 image_manager.cpp:277] Cannot remove images backed by /data in recovery
[ 104.851431] update_engine_sideload E 01-14 19:39:19 648 648 image_manager.cpp:277] Cannot remove images backed by /data in recovery
[ 104.851447] update_engine_sideload E 01-14 19:39:19 648 648 snapshot.cpp:2001] Could not remove all snapshot artifacts
[ 104.851462] update_engine_sideload E 01-14 19:39:19 648 648 snapshot.cpp:291] Could not remove all snapshots
[ 104.851485] update_engine_sideload E 01-14 19:39:19 648 648] [ERROR:dynamic_partition_control_android.cc(538)] snapshot_->CancelUpdate() failed.
[ 104.851505] update_engine_sideload E 01-14 19:39:19 648 648] [ERROR:delta_performer.cc(747)] Unable to initialize partition metadata for slot B
[ 104.851526] update_engine_sideload E 01-14 19:39:19 648 648] [ERROR:download_action.cc(227)] Error ErrorCode::kInstallDeviceOpenError (7) in DeltaPerformer's Write method when processing the received payload -- Terminating processing
[ 104.853130] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:multi_range_http_fetcher.cc(177)] Received transfer terminated.
[ 104.853157] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:multi_range_http_fetcher.cc(129)] TransferEnded w/ code 200
[ 104.853176] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:multi_range_http_fetcher.cc(131)] Terminating.
[ 104.853203] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:action_processor.cc(116)] ActionProcessor: finished DownloadAction with code ErrorCode::kInstallDeviceOpenError
[ 104.853220] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:action_processor.cc(121)] ActionProcessor: Aborting processing due to failure.
[ 104.853239] update_engine_sideload I 01-14 19:39:19 648 648] [INFO:update_attempter_android.cc(584)] Processing Done.
[ 104.853317] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot product_b
[ 104.853358] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot system_b
[ 104.853395] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot odm_b
[ 104.853429] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot system_ext_b
[ 104.853465] update_engine_sideload I 01-14 19:39:19 648 648 snapshot.cpp:2525] Successfully unmapped snapshot vendor_b
[ 104.855961] update_engine_sideload E 01-14 19:39:19 648 648 snapshot.cpp:2782] Open failed: /metadata/ota: No such file or directory
[ 104.982967] ERROR: recovery: Error in /sideload/package.zip (status 1)
[ 105.049557]
[ 105.116464] W:Failed to read /sys/class/thermal/thermal_zone9/temp: Invalid argument
[ 105.123360] W:Failed to read /sys/class/thermal/thermal_zone8/temp: Invalid argument
[ 105.130428] W:Failed to read /sys/class/thermal/thermal_zone71/temp: Invalid argument
[ 105.130482] W:Failed to read /sys/class/thermal/thermal_zone7/temp: Invalid argument
[ 105.131773] W:Failed to read /sys/class/thermal/thermal_zone6/temp: Invalid argument
[ 105.131927] W:Failed to read /sys/class/thermal/thermal_zone5/temp: Invalid argument
[ 105.132071] W:Failed to read /sys/class/thermal/thermal_zone4/temp: Invalid argument
[ 105.132139] W:Failed to read /sys/class/thermal/thermal_zone36/temp: Invalid argument
[ 105.132239] W:Failed to read /sys/class/thermal/thermal_zone3/temp: Invalid argument
[ 105.132400] W:Failed to read /sys/class/thermal/thermal_zone2/temp: Invalid argument
[ 105.132451] W:Failed to read /sys/class/thermal/thermal_zone18/temp: Invalid argument
[ 105.132509] W:Failed to read /sys/class/thermal/thermal_zone15/temp: Invalid argument
[ 105.132541] W:Failed to read /sys/class/thermal/thermal_zone14/temp: Invalid argument
[ 105.132573] W:Failed to read /sys/class/thermal/thermal_zone13/temp: Invalid argument
[ 105.132604] W:Failed to read /sys/class/thermal/thermal_zone12/temp: Invalid argument
[ 105.132636] W:Failed to read /sys/class/thermal/thermal_zone11/temp: Invalid argument
[ 105.132667] W:Failed to read /sys/class/thermal/thermal_zone10/temp: Invalid argument
[ 105.132698] W:Failed to read /sys/class/thermal/thermal_zone1/temp: Invalid argument
[ 105.132729] W:Failed to read /sys/class/thermal/thermal_zone0/temp: Invalid argument
[ 105.132747] I:current maximum temperature: 41300
[ 105.132837] I:/sideload/package.zip
[ 105.132840] 0
[ 105.132842] time_total: 91
[ 105.132844] retry: 0
[ 105.132846] target_build: eng.root.20250111.181155
[ 105.132848] temperature_start: 39000
[ 105.132849] temperature_end: 41300
[ 105.132850] temperature_max: 41300
[ 105.132851]
[ 105.132998] I:Command 0 finished with 0
[ 106.303420] minadbd W 01-14 19:39:20 434 434 sockets.cpp:279] timeout expired while flushing socket, closing
[ 106.303448] minadbd I 01-14 19:39:20 434 452 minadbd_services.cpp:159] revents: 16
[ 106.349328] I:Socket has been closed
[ 106.464422]
[ 106.464453] Install completed with status 1.
[ 106.585145] Installation aborted.
[ 106.652241] I:[libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
[ 226.956349] I:Brightness: 1023 (25%)
[ 346.960340] I:Brightness: 0 (off)
[ 548.246136] I:Brightness: 2047 (50%)
[ 668.249798] I:Brightness: 1023 (25%)
[ 723.392428] I:Brightness: 2047 (50%)
[ 998.058547] I:[libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
[ 1001.102930] Enabled ADB.
[ 1001.169397] I:[libfs_mgr]dt_fstab: Skip disabled entry for partition vendor
That is not the official installation method. I linked it above. Try it.
I know, but this would delete all data on my phone and I still hope to find a way without deleting all data and do a full install. Hence the try with adb sideload
Just a short update:
I’m still not able to use the updater, even in a different OS.
I figured out, it probably is related to missing xbl_b
and xbl_config_b
partitions and opened a new thread here: Missing Partition xbl_b
One suggestion for the sideload method:
From all I know the download address needs to be altered for downloading an update file (instead of the file for full installation from scratch). The “IMG-” part needs to be deleted from the download URL (just to make sure, you are probably aware of this, but anyway: It will not work to just rename the file, the download URL must be altered). So it would read something like https://ota.ecloud.global/official/FP5/e-2.6.3-t-20241217455358-official-FP5.zip
Volker’s link is right, but the specific download URL on that page needs to be altered for the purpose of sideload installation of the update.
Closing here to not fuether duplicate
