Can't answer a phone call
Hello FP2-Users,
since two - three months I have a strange Problem with my FP2. Maybe you have similar ones and you can help me.
Always when I get a phone call it is not easy to answer the call. Reasons or symptoms are:
1.) It just rings/vibrates one time.
2.) On the display you can’t see the phone call.
3.) When I am doing other things with my FP2 and other APPs are open, I can’t just go into the phone answer menu. Before that I need to close all the other APPs even when it is just one APP.
That is complicated to answer a phone and makes the use of the FP2 problematic.
Do you have any ideas for reasons, solution.
Sorry for my bad English, I am not a native speaker. I hope I could explain my issue.
Thanks,
tumkil
Have you had a look here?
It sounds a bit similar…
Thank you, ff2, I think it worked! :slight_smile:
