unfortunately my Fairphone (first batch) is sort-of bricked since last night: When I connect the USB charger or attach the USB cable to my computer, the phone displays the charging sign, but the display turns black after a couple of seconds. The phone then displays the charging screen a couple of seconds again later, and again the screen turns black. This cycle happens to continue forever, and the phone is not charged at all; this makes it impossible to turn on the device, as the battery is fully discharged.
Interestingly, I ran into this problem after applying the Unified Storage Upgrade (Cherry 1.6), and the phone got discharged afterwards.
I donât think this is probably a bug so have moved this to the help category
Unfortunately I donât think there is going to be much we can offer by the way of advice if you canât get any charge into your phone. Itâs perfectly possible to âunbrickâ but obviously you need some charge to get it connected.
I guess when you connect to your computer youâre not able to see the connection?
Iâd suggest contacting support directly as itâs probably going to need to go back for repair/replacement
Hello Chris, I seem to be experiencing sort of the same problem: my FP (1st edition) doesnât charge anymore. I am using different cables that did do the trick until two days ago, so the cables cannot be the problem. The battery gets charged up to 3% only. I cannot open it , not even with FP connected to the power plug. It seems something is wrong with the battery charging port (is that how you call it, but it doesnât show any deformities (I didnât drop it on that spot, or something).
In the FP shop I do not find the âportâ among the spare partsâŠ
What to do?
Yeah, you may want to check you battery first, thereâs a lot on the forum and Fairphoneâs support pages about battery bloating and if thatâs the problem you need to get into contact with support directly.
Hi, I am having the same problem. The phone (batch summer 2014) is not charging and endlessly connecting and disconnecting. With the charging sign coming up and then changing to a black screen.
Thanks for the suggestion! I will try another charger later today when I am back home.
Someone suggested a can of air to get rid of any dust in the USB plug. I think I will try this if an alterative charger doesnât sort it out.
