Camera opens only with the rear function top down - how to fix?
I already tried reset to factory settings with no results.
Funny 5 figure numbers appear in the right upper side of the screen.
Could you post some screenshots, please? I cannot imagine your issue.
Dear Stefan,
have you checked my issue yet?
I am very much in urge to use the camera for business purpose (cam scanner and evernote usage).
Is there a way to check whether the front camera is broke?
Cheers
Jacky
P.S. I speak German too, if that would help.
Anfang der weitergeleiteten Nachricht:
At the moment the camera screen appears completely green.
Dear Stefan,
Cheers
Jacky
If it’s OK for you, I would like to stick with English, maybe someone else can help us then.
I really don’t see the 5 digits you mentioned. Also: Do we speak about the rear or the front camera?
PS: This post suggests that you only need to restart your phone, if you see the green screen.
PPS: Have you tried with an alternative camera app like Open Camera?
Tried restarting, tried open camera - message „Failed to open camera. Camera my be in use by another application“ or acts crazy, freezes, shows green screen. Also when I restart the phone.
Can nobody help in this matter? I need the camera - otherwise I wouldn’t had bought a smartphone.
After reinstalling and update to kola nut - camera still doesn’t work. HOW CAN I CHECK IF THE CAMERA IS BROKE?
Dial *#*#3646633#*#* and you will enter engineering mode. There go to “hardware testing” and choose “camera”. The last option is called “Start preview”. Click it.
Thanks for responding - done, but message appears „engineerMode wurde beendet" - what now?
Did you try a hard reset? :warning: Read carefully!
Thanks, done, but main camera remains dead.
Front camera opens in „up-side-down“ mode, turn-around icon works to turn the front camera to the upright and does make pictures.
Maybe there is „just“ a loose contact in the board??
What now?
I have exactly the same problem. I even installed a new camera, but this did not help.
Really nothing new about this problem?
Best regards
@Jac could you solve your problem?
I’m sorry nobody answered your last post yet. If nothing else helps you both should contact support.
Fairphone had to exchange the motherboard :wink:
Well, bad luck. But thank you very much for the quick answer.
