Camera, language, and network issues after Android 15 update
I have a FP4 that’s been great for years, but after the Android 15 update, I’ve had several issues.
  1. The camera frequently won’t turn on or takes blank/black pictures. If I close and restart the camera app, it usually resolves, but sometimes takes several tries.
  2. I have two languages installed, but several apps and the main menu often use the second language installed, rather than the main system language. I’ve checked the language settings, set the languages for the apps specifically to English and the system default, but neither has fixed the issue. Uninstalling the second language worked, but I do actually need to have the second language installed.
  3. My phone is only connecting to Edge or 2G networks. This might not be related, but it did start within 24 hours of the update. I’ve gone through all the network recommended troubleshooting (restarting, removing the SIM, and some manual network connection reset. T-Mobile is saying it’s the phone or a network outside, since none of that worked, but the issue persists across at least a 25 mile area.
I’m not sure if it’s best to roll back to Android 13, or if this is solvable. Any recommendations would be great, and if rolling back is the best option, is there a good guide to that, including how to prevent the update from installing again in the future? Much appreciated!
