Hi
Since 01st of Jan 2021 the camera on my fairphone 2 is been deactivated based on security guidelines.
Is there anybody out there who knows what had happened and how to overcome it?
Thanks for your support.
Best
Herbert
Welcome to the Fairphone community. Does this discussion possibly help you: Camera deactivated since update 18.01. 1 - - > solved it was Avira Antivirus
I will check it - thanks
YES…
the avira antivirus has deactivated. Thanks for your help.
