Hi, I’ve been using my FP5 for a while now and have noticed that occasionally the camera app doesn’t seem to save photos. I take a photo, hear the shutter click, see it pop up in the bottom left preview corner, and then when I click on said corner or open my gallery, the photo isn’t saved!
This is a really annoying issue, as I absolutely cannot tell if it saves the photo or not unless I go into the gallery, all the other signs seem like it’s fine. It’s not a storage or camera permissions issue as far as I can see.
I think this might be something that happens more with battery saver on, as it takes too long to save or something. I think turning on HDR makes it worse, since it’s got more stuff to process and therefore the time during which you need to keep the screen on for it to (maybe) save properly is longer. Would appreciate a fix for this from the team, it’s been going for a long while.
It happened to me today on my FP5, too. I took a couple of photos, and when I went to the gallery, the photos weren’t there. I didn’t notice the problem at first because I don’t take many photos.
As a follow up, I have finally given this solution a go.
Alas, while the frequency of zero length file images has been reduced, it hasn’t dropped to zero. I’m going to start looking at the recommended F-Droid replacement app next.
