When I try to open the camera app the screen shows just a bunch of colored lines, a message comes up saying “impossible to connect the app to the camera” and then the app turns off. I ordered a new camera module, I replaced it, first it seemed to work fine but then makes the same problem. Did I spend more than 50 euro for nothing? How can I solve the problem?
You could try the things other users did here …
… or here …
Additionally, I’d recommend to try a few different camera apps - just to rule out that it’s a software issue. For example, OpenCamera has often been reported to be working.
2 posts were split to a new topic: Problème avec l’appareil photo
