Call problems while loudspeaker is activated
Hey guys,
I’m using my Fairphone 4 for a few months now and after the last update I have problems with my mobile call quality.
If I use my smartphone with the loudspeaker activated during the call, my voice isn’t recorderd properly and I always sound like I have connection problems.
After I switched back to my regular “private ear loudspeaker” there isn’t that problem anymore.
I assume it’s a software problem.
I also phoned a test hotline to see if the problem is really on my side and I got the same results.
If I talk with my loudspeaker activated I sound like a robot or my voice is interrupted.
I’m using the normal android software and app with no changes.
The strange thing is, if I’m using another apps like Instagram or WhatsApp to call someone I don’t have this kind of problem.
Everything works fine there.
Anyone facing the same problems?
Thanks guys :slight_smile:
Best greetings
Grayscull
Hi!
Yes, same issue here. Been in contact with support on the second day I got my FP4 to report the issue but it hasn’t been resolved since.
It’s really a bummer cause I much prefer to talk on speaker than keeping the phone to my ear all the time.
I’m assuming a software issue as well, but on the other hand you’d think it’d be more widely reported.
Let’s hope the fine people at Fairphone are reading along. :slight_smile:
Hey man,
thanks for the reply.
At least I’m not the only one with that problem.
I already asked the support for help and they told me the following:
Step 1: Update
Make sure to [update to the latest software 11351328932497): Fairphone OS v.095 (Build number FP4.TP25.C.095)
The release of some updates may be delayed by up to a few weeks. This depends on your country and phone carrier.
Step 2: APN settings
Your APN settings affect how your Fairphone 4 connects with the network. To check if they are causing issues:
  1. [Reset your APN settings]
  2. Depending on your network operator, you might need to [set your APN settings manually]
Note, you’ll need to do this step separately for each SIM card you’re using, including eSIMs.
Step 3: Service test
  1. Open the Phone app.
  2. Dial **#[#2886] in the same way you enter a phone number to make a phone call. Once the last character is introduced, the Service Menu appears (be patient, this can take a few seconds).
  3. Select Manu.
  4. Tap on SIM and/or eSIM. You should see sim card is OK and/or ESIM is ok.
  5. Choose FAIL or PASS accordingly based on the result of the test and let me know how it went.
Step 4: Check with your network operator
Contact your operator and ask if there’s currently a network outage in your area - a local cell tower might be damaged or some of their services might be down due to a settings error.
Step 5: Reinstall your SIM card
[Reinstall your eSIM card]
Remove your SIM card and check it for any visible damage.
Note that physical SIM cards are small electronic devices and can be damaged or become faulty with time. If your physical SIM card is older than 2 years or looks scratched, ask your operator to issue you a new one. A new SIM card can fix a lot of [unexpected issues]
Step 6: Try a couple of different SIM cards
Borrow a couple of SIM cards from family members or friends and test them on your device. It’s best if you try with at least one card from the same provider and one from a different provider. Repeat Step 2 for each SIM card you try.
If another SIM card works well, it means something is wrong either with your SIM card or your contract/data plan. Please, contact your provider if that’s the case.
Does your SIM card work in another phone? Let me know.
Step 7: SIM status
  1. Go to Settings → About phone → SIM status.
  2. Take a screenshot and attach it with your next reply.
I already checked and tried what they told me but it didn’t help.
Bonjour,
On m’a dit qu’il y a trois micros sur le FP4. Lorsqu’on utilise le Haut Parleur, deux micros sont désactivés et le seul qui reste est celui situé à gauche du FP, exactement à où on prend l’appareil en main et on met souvent le pouce sur ce micro. C’est une erreur de conception. N’y a t-il pas moyen de désactiver ce microphone et activer soit celui du haut soit celui du bas? Je pense qu’il s’agit d’un problème de paramètres que les techniciens de FP pourraient résoudre.
Good morning,
I’ve been told there are three mics on the FP4. When using the Speaker, two microphones are deactivated and the only one that remains is the one located to the left of the FP, exactly where you hold the device and often place your thumb on this microphone. This is a design error. Is there no way to deactivate this microphone and activate either the top or bottom one? I think this is a settings issue that FP techs could fix.
Bonjour Noel,
thank you for your reply.
Unfortunately, this is not the case.
Most of the time I’m holding the phone, that the left microphone isn’t blocked or I just put it on the table so I don’t have to hold it.
Fairphone already replied on my comment to their solution, wich I posted above and now they will ask their tech department.
Let’s see what they will tell me.
I have the same issue since some weeks or months.
I would assume that the issue was triggered with some firmware version change as everything was working before.
Whenever an app starts a call and relies on the loudspeaker, then people on the other end wont be able to hear me at all.
When I switch back and not use the loudspeaker other people will hear me fine.
When connecting bluetooth headsets other side can here me.
Issue occurs with android default call app and all other apps that rely on call or video call functionality.
My build on FP4
fp4.tp29.c.0101.20240121
Hey,
yes the same goes for me but only if I’m doing a normal phone call.
Well Fairphone wrote me back and they sugessted me to send in the smartphone.
Before I will do that, I will do a factory reset.
I will inform you about the outcome.
Greetings
Grayscull
Please make a backup before a factory reset.
Because a factory reset will erase all your (personal) data.
Same problem w/ my FP4: people on the other side do not hear me properly (interruptions) when calling ‘normal’/loudspeaker.
I also think that the left mic is a design fault because it is automatically covered by my hand when picking up a call.
My FP4 is up to date, my APN is correctly set, wifi-calling is off and sim-card is ok.
Following advice from FP did not help:
  • If your provider does not offer 5G or you do not have a 5G contract, having your device set on 5G can mess with phone calls and the general functioning of your SD card hence why we ask you to try other connection settings.*
  • As for wifi-calling, it could be because your network provider offers this service. This allows you to make high-quality phone calls using Voice over LTE (VoLTE) or Voice over Wi-Fi calling (VoWi-Fi) on your Fairphone 4 and does not require to have a specific subscription as far as I am aware.*
  • It can also be that when setting up your SIM card this was automatically selected as per some automatic settings decided by your provider.*
  • FP4 is technically capable of using VoLTE and VoWiFi technologies but we are still working on completing the partnerships with some network providers.*
  • This is why, in cases like yours where customers are experiencing any issue related to calls, we strongly advise disabling them for the time being, as they might be causing incompatibilities with your network operator.*
Hope there will be a solution to this ‘hearing probleem’ soon!
Hello all,
@Lidwien
thanks for the headup, but I also did that :slight_smile:
Well after my update to the newest software version I was facing the same problems again.
I’m in contact with the support.
Best Regards
Grayscull
Same problem over here with a brand new FP4 running on Android. Is there any bugfix or workaround from Fairphone yet?
Hey Luke,
nope not yet.
I will update you, when the support of Fariphone will contact me.
Best Regards
Grayscull
Thank you very much :slight_smile:
Hey Luke,
well I need to send in my phone.
I’m gonna do that in June.
Will update you after I did that.
Hey Luke,
well I sent in my phone and they repaired it.
I’m gonna get it in a few days.
In the report they stated that the microphone was faulty and it had distortion.
I gonna update you when I have my phone back.
Greetings
Grayscull
Hey man
Please look at the answer to Luke :slight_smile:
Hey TLJ
Please also take a look at my answer to Luke :slight_smile:
Hey Grayscull,
thanks for keeping me updated! :slight_smile: I hope it’s not the microphone with mine as well. But I’m excited about your repairing-report.
Hey Luke,
got my phone back today.
Still doesn’t work.
Im in contact with the support again.
I have had the same problem since my Fairphone 4 was new (2022). I’m kind of glad to hear so many are facing the same issue…
A long time ago I contacted the Fairphone support and got the instructions to do the mic tests (mentioned in this thread). No fault was detected then but the problem remained. I didn’t have time or energy to continue solving it with the support so I just let it be.
To me, there has been no changes after the updates. The problem was there in the first place and still is. But what I learned from this thread is that it might not happen in Skype, Signal, Meet etc. calls. I have to test this next.
Maria
