I have a FP5 and updated to FP5.VT2P.C.089.20260311 and since then when I call or get a call the person at the other end of the call can’t hear me. I hear them perfectly. If I switch to a speaker, everythin is ok and they hear me again.
This happens on the phone as well as with WhatsApp calls.
Also, recording on the voice recorder works.
Did the update break something or do I need to buy spare parts. It’s possible that it’s just a coincidence that the mic stopped working around the same time the update arrived.
Its not about actual pairing or registeringof hearing aids, but the setting regarding compatibility, see the link in my previous answer. Is this setting disabled?
I have the same problem. After Update to FP5.VT2P.C.089 the main microphone does not work anymore. I tested with calls and audio record tool. I did the *#*#2886#*#* selftest for audio and micdb. Result: main microphone records only strange noises while mic 2 and 3 work correct. This might explain why calls with speaker (hands free mode) might work. I created a support ticket today. Might be an software issue if that happend to you also. I decided to wait for the result of this ticket before i send in my device for repair.
The question here is if there is an connection between update FP5.VT2P.C.089 which was released 2026/03/30 and the defective microphone. In my case i had the last successfull call at 2026/04/03. Unfortunately i cant exactly remember when i was notified about the update and on which day i installed it. The micropone was defenityly not working at my next call on 2026/04/11. Probably the first call after i did the update…. Could be an software issue related to the update, but there is still a chance the hardware got randomly defective for multible users in this time period.
Got no response for my support ticket within 2 weeks. The issue persists also after the following update and factory reset… Since only a few people were affected it is more likely a hardware issue. I now sent in the device for warranty repair.
My device was in France for repair. This was surprisingly easy and even faster than jet unanswered software support ticket . According to the repair documentation I received, they changed the cable between top (pcba) and bottom (pcbb) module. And they did an software update. I am curious why since I installed the latest available update FP5.VT2Q.C.092 2026/04/20 before I did factory reset and sent in the device for repair. Probably they just reflashed the latest software with an professional jtag/flash adapter to get a clean factory reset state by default? The device is on the way back to me, so i’ll check mic1 and the software version first
From the tech report:
Failure Declared by the customer : MICROPHONE - FAULTY
I tried the service menu: audio and micdb tests failed. mic 1 is not working. Makes strange noises. Mic 2 and mic 3 appear to work.
FAILURE1: MICRO – HS
REPAIR : ELECTRO/MECHANICAL
PARTS CHANGE: FP5_PCBA_LINK_FPC_CABLE_V1 Grade E
FAILURE2: NO FAILURE
REPAIR: SOFTWARE UPDATE (preventive)
My personal opinion:
According to the https://www.fairphone.com/wp-content/uploads/2024/02/Fairphone5_Information-on-how-to-repair-and-recycle-SCH-09-02-2024.pdf schematics mic1 is connected to the Qualcomm WCD9385 cpu directly over this cable. An connection issue at this cable at Pin 1,2 or 3 (at one of the connectors) leads to the mic not working.
If you have no warranty left or willing to try an self repair attempt (at your own risk) it might help to carefully check/clean cable contacts and reinstall this cable for better connection?
Remember: I am NOT an fairphone technician and this was a specific fault at my device, yours can have various other issues.
i have currently a similar issue. my mic1 records a strong “tock” with a finger a the mic1 opening (in micdb test), but no voice or just scratching at the opening. So it is recording some kind like a digital 1 / 0 rather than analog audio.
I would like to exchange bottom PCBA and the cable FP5_PCBA_LINK_FPC_CABLE_V1
Just to have both at hand, as i expect one of these is causing the issue.
So far i have not found a source for these parts. if anybody has a damaged Phone (e. g. display) where these components might be ok, i would be interested to buy it..
I’m experiencing the same issue where the microphone doesn’t work (except on speakerphone), but it happens intermittently. It stops working for 10 days, then starts working again. I’ve initiated the return process, but I’m worried they won’t find anything during the workshop test. Do you have any updates on the cause of the problem—hardware or software?
My phone ended up having a list of issues: microphone, camera opening when trying to lock screen, green frames flickering when playing back slow no video, freezing all together, when trying to shoot video…
I eventually contacted the support with the list and they asked me to send my phone over.
The service was very fast, and just last week I got a brand new phone. I guess they figured it’s not repairable and it’s better to use the parts for something else.
