Bugs: fairphone 5 // IodéOS 7
I would like to report several bugs or if not, search for operating instructions.
Phone: Fairphone 5
Android Versions IodéOS 7.1, 7.0, 6.9,
Dual SIM operation with physical SIM and e-SIM
  1. Most important bug: Dual SIM operation primary SIM. Settings:
  • Network : SIM cards : Automatically switch SIM for data: on.
  • Network : SIM cards : Primary SIM : Mobile data: Physical SIM
This setting is changed arbitrarily; after leaving a Wi-Fi network or while bad connection, the other SIM is suddenly used and changed in the primary settings.
  1. Network : SIM cards : Mobile data on/off: This button can only be set for both SIM cards together! In the standard Android version, this is switched separately for each SIM card under Network : SIM cards : SIM ½. This is a very necessary item.
  2. Under Network : SIM cards : SIM 1/ 2 : Roaming: on/off. This switch does not work. The data connection is also used when roaming, on both SIMs. No effect at all.
  3. Network connection interruption causes the media volume to be set to 0. This means, for example, that every time you cross a national border, the volume is reduced to 0.
I am happy to help by answering questions, posting screenshots or conducting further tests.
Best,
Dieter
