Now I run my FP3+ with the beta-version (/e/ OS Q (Android 10) for FP3/FP3+). Even it’s possible to do phone calls with the newest update.
But it’s only possible by the big loudspeaker on the bottom. While calling the display is quite normal without the sign for the big loudspeaker and for the one I call to its a difference when I push this button. But for me everything I hear comes out of the big loudspeaker on the bottom and not as usual from the little device on the top of the smartphone.
Does anyone have this problem too and solved it?
I even can’t regulate the loudness of the output of the loudspeaker (by calling, not by any other media like music.)
This is a known bug: https://gitlab.e.foundation/e/backlog/-/issues/2039
To see all current open issues about the /e/ Q release on FP3 see here: https://gitlab.e.foundation/e/backlog/-/issues?scope=all&utf8=✓&state=opened&label_name[]=q&label_name[]=FP3%2FFP3%2B
Hi Ingo,
thanks for your answer.
Unfortunately, I’m not so adept in these things.
So: I’ve to change the program. For this, I have to open the file android/snippets/lineage.xml, right? How do I get the file? Via PC oder on the FP3+ directly? Do I change it via an editor? And for this do I neet root rights?
You don’t need to do anything. Just wait until a new update is available where this bug is fixed.
Having to wait seems a bit random, it could be ages
@piano maybe move back to the default ROM for now ?
I don’t understand that. This is nothing a user can fix themselves, they would always have to wait for the manufacturer to act.
Why download a Beta, if you don’t have the Patience to wait until Problems are solved?
I mean the time to wait is unknown
