Bottom microphone replacement
Hello
Which spare part of the FP6 includes the bottom microphone ?
Thanks !
None mics are on the core module
I don’t think that’s correct. There is a “bottom” module, but it’s not user-replaceable (only the bottom speaker part is). In the teardown you can clearly see that it’s certainly not the core module:
If you need this part replaced, you’d have to send the phone in. But as it’s not the core module, the price should be more acceptable.
