Dear Community,
I’ve seen a lot of posts regarding bluetooth not working (with car, other FP, trackers, etc) but haven’t seen any single solution to that issue so far.
In my case, my bluetooth works but drops after few seconds. No matter with which device, I’ve tried connecting with other smartphones, my laptop, nothing works, and it doesn’t even try to work with my logitech headset. Also, the apps doesn’t seem to get access to the Bluetooth (banking Apps and ID apps).
I’ve done the whole procedure proposed step by step, again and again, deleting cash memory, unpairing and deleting pairing devices in all devices, etc. And went through the phone reset, making a light reset, e.i. no back-up of any kind.
Also removed the memory card.
Still the same issue.
Therefore, I was hopping that someone, since then, had his issue solved (because I think they are all related), and would be kind enough to share it here.
Thank you
