Bluetooth LE loses connection after 24h
I use a bluetooth LE connection for a device called Freestyle Libre, a blood glocose sensor. I noticed that my Fairphone 4 loses the connection after around 24h. After that I have to actively wake up the connection (in this case: using a NFC scan) and everything is working for the next 24h.
I addition to that I use a Xiaomi Mi Band 4 via BT (I assue LE too), but that connection is totally stable.
Since this is a important medical device for me and I did not encounter those issues with other phones I was curious if this is a configuration issue on the fairphone?
I dump a part of my adb shell dumpsys bluetooth_manager in the working state:
Bluetooth Status
  enabled: true
  state: ON
  address: XX:XX:XX:XX:XX:XX
  name: MY Fairphone 4
  time since enabled: 41:12:22.516
Enable log:
  01-12 16:00:03  Enabled  due to SYSTEM_BOOT by android
0 BLE apps registered
BluetoothManagerService:
  mEnable:true
  mQuietEnable:false
  mEnableExternal:true
  mQuietEnableExternal:false
AdapterProperties
  Name:  MY Fairphone 4
  Address: XX:XX:XX:XX:XX:XX
  BluetoothClass: null
  ScanMode: SCAN_MODE_CONNECTABLE
  ConnectionState: STATE_DISCONNECTED
  State: ON
  MaxConnectedAudioDevices: 5
  A2dpOffloadEnabled: true
  Discovering: false
  DiscoveryEndMs: 0
  Bonded devices:
    YY:YY:YY:YY:YY:YY [BR/EDR] BT MP3
mSnoopLogSettingAtEnable = empty
mDefaultSnoopLogSettingAtEnable = null
GATT Client Map
  Entries: 2
  com.freestylelibre.app.de (Registered)
  LE scans (started/stopped)         : 0 / 0
  Scan time in ms (min/max/avg/total): 0 / 0 / 0 / 0
  Total number of results            : 0
  Application ID                     : 6
  UUID                               : a18e9665-090b-44c5-99f8-b5d3d32c42c5
  Connections: 1
    01-14 02:26:43 - 24326927ms : 18:32:19:0A:02:DA (6)
  com.eveningoutpost.dexdrip (Registered)
  Application ID                     : 9
  UUID                               : f67402b9-a42c-4b92-b280-fa5ff5996b2c
  Connections: 1
    01-12 16:01:07 - 148262007ms : ED:54:44:B5:9C:A3 (265)
Go to settings, search for “battery optimisation”, click on “battery optimisation”, change the filter to “all apps”, search for “Bluetooth”, change to “Don’t optimise” and see if this fixes your problem. If not, you should contact support.
Thank you, I will try it.
I just had my daily 24h disconnect without the Bluetooth app battery optimization. But I will observe the behavior for a few more days (and after a reboot) before contacting the support, just to be sure.
Did you disable battery optimisations for the FreeStyle Libre app as well?
Maybe that’s the one that’s actually getting killed :thinking:
Sure, I did this in advance, because I knew this could be an issue from other phones. I was not aware that I could try this on the bluetooth app itself.
Sadly the problem still remains, even after disabling the battery optimization for bluetooth and affected apps. :frowning: Thank you for your ideas so far. I gonna contact the official support now.
Sorry to resurect this thread. But as a diabetic who plans on getting a fairphone 4, were you able to resolve the issue?
Hi and welcome to the forum.
It hadn’t actually died it was just a bit sleepy
Thanks for keeping it breathing
Official support could not help me because they “do not do 3rd party debugging”.
I noticed that the disconnect occurs exactly every 24 hours, and for me at just before 3 pm, or just before 2 pm in daylight saving time.
I also noticed that starting the Freestyle Libre (patched) app resurrects the connection. Accordingly, I use an automation via Tasker, which starts the app once a day (around 3 pm).
I believe that this is not at all a Bluetooth issue, but a battery optimization issue caused by some kind of daily scheduled clean up job.
Do you need to restart the connection after it dies or is it enough to have it started 1-2 hours before it dies?
Also, sorry for double post and off topic. How is the battery life when you are using libre 3?
You have to restart after the connection dies.
I’m using libre 2 patched app with xdrip, not libre 3. But I have never experienced drastic battery consumption via BTLE ever.
