Blue light filter screen protector from Fairphone, your remarks
First, I create a new topic because this one is closed: “Blue light filter screen protector - What’s the screen quality after applying it?”
I received the blue light filter screen protector, it was free (promotion of Fairphone). I noticed there is two screen protector sold by Fairphone (the privacy filter and the blue light filter). In my case, they sent me the second. Are you satisfied with it ? Do you encounter the same problems as privacy filter ? it seems to not easy to install, so have you got advices ? is it easy to remove it once it is installed ? What can you tell me about it ?
Thanks.
A post was merged into an existing topic: Blue light filter screen protector - What’s the screen quality after applying it?
