Yes. The phone should then be in the same condition as after entering the SIM-PIN. Would be sad if no one could call you, when your phone is in your pocket, and locked.
So SIM PIN means SIM is permanently unlocked.
Edit: To check, I have rebooted my FP4 and entered the SIM code. Then I gave it a call and it worked.
Other than my Samsung work phone. This I can only call after once logging on to the phone with the screen PIN. Maybe itâs my companyâs default setting as an additional security feature. But it is not standard on the FP4. So, removing the PIN and calling it should make it ring, if it is alive after the update, only black screened.
Yes, and if you unclick it, the PIN will be deactivated on the SIM card. So, if you do this on another device and put it back to a black screened FP4, the question is if it is callable after booting up.
But this is something only someone with an affected phone can tell us.
Would the fix be Fairphone releasing the 2nd version of FP4OS running on A13 as an OTA Sideload update here, so we could Sideload it to get it running again or am I not getting something?
I am hoping to hear something by tomorrow. But as the support cannot promise anything, i cant eitherâŚ
But i can add info about my FP4.
I bought it around christmas '22 and i tried LineageOS. But i did not want to keep the bootloader unlocked, so i went back to Fairphone OS and stayed with that since that time.
Did anyone have this problem without having tried another OS on the FP4? I did not read anyone exactly stating that, although trULLAs post sounded like she just uses the FairphoneOS.
I just wanted to add that Iâm experiencing the same black screen issue thatâs described in multiple posts here. The phone was fine until the attempted upgrade to Android 13. Now it boots up, the Fairphone splash-screen shows for a second, then itâs just a black screen with backlight for about a minute.
FP4 from December 2021
Previously installed LineageOS, but for the last 6 months have been running the stock OS, boot loader, etc. from Fairphone, with default settings.
No changes to the phone, root not enabled.
Using Termux and Password Store from fdroid, otherwise all apps are from the Google Play Store
i donât remember wether adb-debugging was on or off.
is it possible to check it from âfastbootâ, or from âadb sideloadâ, or from âadb unauthorizedâ states?
my FP4 was baught on January 2023.
i previously installed LineageOS, but then changed it back to the stock OS.
Update Oct 12th:
It very much looks like previous installation of a custom ROM causes some sort of screen issues, but does not brick the phone completely:
This also means that if you did not install a custom ROM on your phone in the past, you should not be affected by this particular problem.
Original post and overview:
I went though all the reports here and will try to sum up the information people gave about their phone setups to get an idea what those might have in common. Thanks @USB-2 for the idea! (click the arrow for details)
Unfortunately, not a whole lot of reports include the relevant information. So Iâm tagging those here in hopes that they might still add that information:
Overview of people/phones with problems and their setups
@Tuzzaman: G33K2303: Divest OS according to this M4rk: used custom ROMs (LOS), bootloader locked @Martin_1964: open bootloader, no information on custom ROMs - please specify! according to this LOS as well Munk: used custom ROMs, locked bootloader GunniMator: used custom ROMs (LOS) Devilicate: previously rooted and used custom ROMs, bootloader locked urglas: used custom ROMs (LOS), bootloader locked ogghi: used custom ROMs (LOS), bootloader locked soyatti: used custom ROMs (LOS) dylanwhyte: used custom ROMs (LOS) Phk: used custom ROMs (LOS), bootloader open
Conclusion based on this spotty information: Most of people with the issue who reported back have installed a custom ROM at some point in the past! This would be 100% if we knew for sure what @Martin_1964 was up to. I guess you donât unlock the bootloader just for fun.
To be clear: Iâm not convinced that this is the whole picture, as at least some of the other posts could be read in a way that suggests absolutely no modifications at any point in the past. But the only way to be sure is if those people also reported back, so please do if you can!
Same for me, I switched to LineageOS after I bought the Fairphone. After problems with my banking app, I went back to the stock Fairphone OS and lock the bootloader. That was 5 months ago.
Yes I was using custom roms, but I moved back to stock and locked bootloader a while before this issue. I had gotten a couple of smaller updates before this.
Does anyone know if flashing a custom rom would resolve the issue?
